LED false doesn't work with slew - standalone
ericzang
Postby ericzang » Tue May 03, 2011 7:54 am
In standalone mode, with a foot on, toggle 127, slew activated, the LED does not receive a FALSE signal.
So in this case, I want it to be green when the value is not 0 (true), and red when it is zero (false). Currently it is remaining green even when the value is 0.
when slew is at 0, the LED works properly
Keith
Head Honcho
Re: LED false doesn't work with slew - standalone
Postby Keith » Thu May 05, 2011 2:40 pm
How long is your slew time? Slew will slow down the value so it will take whatever slew time you set for it to reach zero. And in Toggle mode it has to come down all the way from 127.
Maybe set up a second ModLine that follows this one but with no Slew.
- Keith
ericzang
Postby ericzang » Sat May 07, 2011 9:33 am
slew is at 3000. I tried 300 and false still doesn't register. Slew at 50 does allow false to register.
Thanks for the second modline idea. This works! I have it set to the expander output, which I don't use, so that the modline is just being a place holder. pic attached[attachment=0]slew led ok.JPG[/attachment]
(91.29 KiB) Downloaded 67 times
