Softstep bug
jusplayinmybass
Softstep bug
Postby jusplayinmybass » Sun Apr 05, 2015 1:43 pm
My SoftStep 2 works great in most situations. But in a couple churches with organs, my SoftStep sets up just fine. But when the organist starts playing, my SoftStep stops responding. I unplug it and start the editor over again (I am in hosted mode) and it works. But my LEDs and display don't respond properly. I am on Yosemite. Am I the only one with this problem?
Re: Softstep bug
Postby TheOtherSupport@KMI » Mon Apr 06, 2015 6:04 am
Sounds like the organ is causing a small hiccup in either the data or power stream on the USB cable/port.
Not really sure what to tell you other than making sure all of your connections are stable, and perhaps consider a shorter cable. Long USB runs are susceptible to dropped connections.
jusplayinmybass
Re: Softstep bug
Postby jusplayinmybass » Fri Apr 10, 2015 3:54 pm
Thanks for the reply. I will try your suggestion. I thought I would avoid this by using a powered hub. Guess not.
