2 softsteps
ineedhelp
2 softsteps
Postby ineedhelp » Mon May 18, 2015 5:03 pm
would it be difficult to run two softsteps at once on the same ableton project?
everything would be CC under midi mapping
Re: 2 softsteps
Postby TheOtherSupport@KMI » Tue May 19, 2015 5:57 am
Nope, that should be totally fine. Just make sure they are sending MIDI on a different channel, or using unique CCs
luedmo
Re: 2 softsteps
Postby luedmo » Sun Aug 30, 2015 11:58 pm
TheOtherSupport@KMI wrote:Nope, that should be totally fine. Just make sure they are sending MIDI on a different channel, or using unique CCs
I have a SS1 and SS2 and 1 x MIDI expander
Do we need 2 x MIDI Expanders to hook up 2 x SS to run together?
Thanks for your help
:Lu
Re: 2 softsteps
Postby TheOtherSupport@KMI » Mon Aug 31, 2015 5:11 am
Not if you are simply connecting to a computer.
If you are controlling MIDI hardware via 5 pin MIDI connection, then yes you would need 2 MIDI expanders.
luedmo
Re: 2 softsteps
Postby luedmo » Fri Sep 04, 2015 10:10 am
Thanks for the explanation :)
:Lu
TheOtherSupport@KMI wrote:Not if you are simply connecting to a computer.
