Nav Pad N/S display counter can't update fast enough
ericzang
Postby ericzang » Tue Feb 15, 2011 7:33 pm
I've assigned the North & South (up/down) NAV pad buttons to cycle through 8 numbers (1-8) in the Y Counter (using with mobius track selection). I've found that when pressing very quickly many times that, although the command is sent successfully every time and the mobius track selection does change, the SS Y Counter display cannot always keep up (doesn't always change its number) and results in the Y Counter display number being out of sync with mobius' track selection.
Also, the Y Counter reset buttonn (circular arrow) does not function when the min value is greater than 0.
Thanks for your help and all your hard work!
