Faulty Backlight
Re: Faulty Backlight
Postby TheSupport@KMI » Mon Oct 08, 2012 12:27 pm
It's working fine on our Windows 7, 64-bit machines here.
Plug in, boot editor, switch to Standalone, turn off EL in settings, save settings, download scenes — BAM, lights are off and I can unplug and replug as many times as I want, no lights. Doesn't matter if the editor is open or not — same results. They light up for a second or two right when it's plugged in, but promptly turn off on their own, as they should.
dirk
Postby dirk » Mon Oct 08, 2012 3:13 pm
Ah there in lies the rub, stand alone mode. It won't ever hold the EL off in Hosted mode, ever.
Perhaps I didn't mention that's the only mode I use the SS with.
Cheers,
Dirk
Postby TheSupport@KMI » Mon Oct 08, 2012 3:27 pm
If you do the trick for Standalone mode it will hold its off state in Hosted mode as well.
dirk
Postby dirk » Wed Oct 10, 2012 5:20 am
Interesting,
I would have not thought of that because all my uses won't transfer to stand alone mode. I guess I'll just make something specific to do that, hey it's worth a shot.
Thanks,
Dirk
dirk
Postby dirk » Sun Oct 14, 2012 12:31 pm
Hurrah and kudos to you TheSupport@KMI, I would have never thought of that fix since I never touch stand alone mode.
Many thanks to you for my making musical life a little easier! :)
Dirk
