Using softstep with an iphone
rmcrobie
Postby rmcrobie » Tue Dec 04, 2012 9:59 am
Is it still possible to use the softstep with an iphone or has apple disabled support for the camera connection kit outside of the ipad? What about iphone 5?
SLP
Re: Using softstep with an iphone
Postby SLP » Sat Dec 08, 2012 3:11 pm
Ipad camera kit(what you need to connect) doesn't support iphone 4s, I don't think it supports others as well.
Works well with Ipad though.
guitarfukit
Postby guitarfukit » Thu Sep 18, 2014 1:46 am
Bump. So softstep wont work with new iphones? Was hoping to use loopy app in iphone with softstep and guitar
Postby emmett@KMI » Thu Sep 18, 2014 3:32 pm
It's my understanding that the reason iPhone 4/4S is thought to be incompatible with camera connection kits is because Apple locked off that functionality. Then with iOS 7 they returned the functionality.
I have personally used the QuNexus and SoftStep with my iPhone 4S via an Apple camera connection kit and it works perfect.
iPhone 5 and beyond should work but you need the alternative lightning connection kit.
Lid55
Postby Lid55 » Sat Sep 20, 2014 6:26 am
I'm successfully using SoftStep, LoopyHD, CCK, with iPad2 and iPhone4. Although iPhone4 works.... it's slooooow to use the UI... especially if using AudioBus and any FX chains. In fact, to use FX chains the latency setting in AudioBus needs to be so high that live playing becomes very difficult due to the delay. So I use my iPad2 mainly, and I'm considering an iPhone upgrade.
Dead Mah-Zie
Postby Dead Mah-Zie » Thu Feb 19, 2015 11:00 am
Lid55 wrote:I'm successfully using SoftStep, LoopyHD
Hi, can you tell me how did you programm your SS to use Loopy? Which pad have you adjusted to which binding?
Lid55
Postby Lid55 » Mon Mar 02, 2015 7:23 am
have you checked out the Loopy forum yet? Lots of discussion about that there.
http://forum.loopyapp.com
