BIGFOOT MODE
vanceg
BIGFOOT MODE
Postby vanceg » Wed Mar 09, 2011 10:19 pm
This is a bit of a cross-posting as I included most of this text in a post on the SoftStep Feature Request page. But I'm hoping that someone else here might be able to come up with an interesting way to achieve the functionality I'm looking for. Afterall, the ModLine system is very powerful and flexible...perhaps I simply haven't been looking at the challenge in the right way. Maybe someone else has come up with a solution.
Here's the issue:
I love controlling parameter values using the "Y Increment" parameter.
However, this requires me to be fairly precise with my foot motion. I've been thinking I'd like to make larger, more course foot motions which don't require me to be quite as precise as I need to when I'm stepping on just one key.
What I was envisioning was perhaps using two keys positioned above/below each other as one pedal. I'm referring to this as "Bigfoot Mode"
What I'm imagining is programming key 6 to be the "Increment" key, and key 1 do be the "decrement" key and assigning both of these to send the same outgoing MIDI message. When I step on key 1, the value starts incrementing (as it would if you stepped on the top half of a key which had "Y increment" set as it's source). When you step on key 6, the value would start decreasing (as if you had stepped on the bottom half of a key which had "Y increment set as it's source).
The harder you press, the faster the increment/decrement happens. Take your foot off, and the in/decrement stops.
All this gives us is the ability to use TWO keys to create a "footpedal like" interface rather than just one.
I'm thinking two new sources called "Pressure Increment" and "Pressure Decrement" would almost get us there. But they would need to be placed on two separate keys, so they would need some way to communicate with each other (I guess a little like the "NavYx10+key" communicates data between keys).
I tried pretty hard to program something like this using Pressure Live or Pressure Latch, and even trying to use the Y Increment on two keys, with the values of one reversed.... but ultimately I couldn't figure out a way to make this work. I keep getting stuck on the the fact that each key has to know the current value of the other key so that it can "increment" or "decrement" accurately and not just jump to a new value.
So this is either a New Feature request, OR a request for someone to say "Hey, there IS a way to pull this off using the current software".
Thoughts KMI or others?
vanceg
Re: BIGFOOT MODE
Postby vanceg » Fri Mar 11, 2011 7:35 pm
Well, I suppose it should make me feel good that nobody else said "Hey, it's OBVIOUS how to do that, you simply......"
Perhaps this is a feature request
Macciza
Re: BIGFOOT MODE
Postby Macciza » Fri Mar 11, 2011 7:54 pm
High Vance
Had similar thoughts myself seperate inc/dec pads unfortunately I dont think it is possible atm . . .
Have not had the change to attack the issue again, because I can't see how to share state between pads.
Wold be a good feature and I'm sure we will get it eventually
Cheers
MM
Macciza
Re: BIGFOOT MODE
Postby Macciza » Sat Mar 12, 2011 6:22 am
And then since posting I had another thought when I remembered that some controllers send and some units receive an 'inc / dec ' midi message, will have to look it up evn though this might not help your problem
Cheers
MM
vanceg
Re: BIGFOOT MODE
Postby vanceg » Sat Mar 12, 2011 6:07 pm
Are you referring to the receiving device dealing with the "relative" aspect of the Increment/Decrement? Yes, this surely is an option. As is writing a Max patch to solve this problem. I really appreciate your input. Yes!
And/but/also: This seems like a feature which could be quite useful to folks and I could imagine that it KMI might want to consider as a feature.
kasper_toeplitz
Re: BIGFOOT MODE
Postby kasper_toeplitz » Tue Mar 15, 2011 8:36 am
to adress this (kind of) needs and a lot of similar ones I simply decided not to upgarde to the most recent SS software/firmware, so it sends the "raw" data of its sensors (that's 4 CC by pedal) - which i am receiving in Max.
Then for this particular need, what is possible is either to make values from pedal 1 negative (so it would be from 0-> -508) when pedal 6 are positives (0->508) and then you sum both and send this value to the given param (you can scale the result to 0-127 - or 0.-1.)
And a way (I did it with "pipe" object) to send the "last" value when you release the pedals....
Or, as you suggest, take the inc-dec route, and assing the 6 to do inc as long as it is pressed and 1 dec. Then you could make faster inc/dec depending of the pressure you apply.
of course it works only if you use max or a similar software (super collider, Pd etc). I would really love that SS implement a modline (in stand alone) called "raw" - or max or anything - which would just output those. with 4 CC by peadal + 4 for the nav pad its 44 CCs, since the standalone limit is 49 it would work, and based on those infos you could do pretty much whatever you want PLUS share little patches etc among users....
and just a "talk-back" command to be able to control LEDS and Alphanumeric from the app !!!
anyhow
should anyone be interested by my max patch (designed for my needs, but easy to expand) I would be glad to send it to you
all the best
kasper
Macciza
Re: BIGFOOT MODE
Postby Macciza » Tue Mar 15, 2011 8:33 pm
Yeah I'd be keen to have a look at your Max patch, not had much time to do much in Max of late so I have not developed anything yet.
Cheers
MM
kasper_toeplitz
Re: BIGFOOT MODE
Postby kasper_toeplitz » Wed Mar 16, 2011 1:47 pm
here it is - my max patch
have a look inside the patchers (switch1 switch2 etc) as more controls are there. from this patch to connect anything to anything in max is easy (a send-receive, or a direct connection)
the only 3rd party object is, i think "sum" (could also be Lsum) - easy to find on the web at maxobjects
any comments welcome - but remember it was done for my own needs: so far it seems to do pretty much anything I want/need
best
kasper
----------begin_max5_patcher----------
33681.3oM68t0iqhjznnOOqeEVKMOMZ0KQdkjyCizYTKMOLO1ONZqkrKSUEm
xkskMU0e6yVm+6GfHAC3DH.aCAUSK0dU1XvQDYbKiLt7+4a+suu4v+S34uu5
+qU+2U+s+1+mu829aYeT5G72ru+u882W++7zt0my9Zee+GuuI7z2+Aboiqie
50n8u7qSgOECOFeN+md+XkTpR+Gte5qrjWW8+xdOaNbZa3omNr6vI3NXYekh
W7J8cO7Q7tv33+2GCgu52i1G+8er56aVu+kuW7sd9v938qeO6678+uOEsdWN
7s4Eb+Nwg+OwM+MYk+lIO98urK62xy9Yuh8mIEPOG8+a1MG7SuKOxyOs19H+
YP9CsFL48SiumxX9gy+pLHlrDEsOgrksfwreXz1LpygM++7arue4KBD3ruIO
8C++6aeK8kefkaH7OSdheuDUL6iO1J+QFYQng+w6J9ilVyq9OXV8cSt6h7vc
SdjkQovSVhhkpj7aEsK7yvSmiNruzy8u88KHNKCUUo.xJsmH6M9kP7Tt0cGd
5svsk3s9aeea3y84Yb3X39KeeOKG3kWp9Mi1e7T34v8wqis.d4e20erK9WkI
hY+7Nt9yqeJrwa14Zye66ubJZ6g8o.Qk6L8iy+4Rv2LkHoudAty9F6WezwMG
e3vtMqO8Yz4nMf7Tw5PBe758QuuNNLNBfGtWw8E89wSo7UkeVg6Wm7Ld87Sm
NraWkGEbkOcbksgeF8T3eFsM9UPX1qzO+E8rk3apHgU4yaSRqpz1tn8gkufC
gNU1xOG9G4Uxbtk6pHl0tnVyhaWKxIJcAGZkZRyzeKW6D7G+Xfzw2COed8Kg
NIj+cVJSANRIOiyTJth+zMo79SF4tIi7lIir6HYrE1wWRjwvQC8.WDBPxNNZ
zPwjSCOFcLbkGBtQMP7.etTFpQIkiDkrrSocvz4C9cnvQpb4uIBpVEGBS7RS
m7e9+v4ewpABMSvc5m3s4qXiNDUegTM8Zm6RTfYjYKvFXoUSMMyZBIKv.CW4
NguHLzKgA+wQXnM6CgqeC4RrWlTgh0qk3R+ynIeXZlpJlH4CqtjE4i9IeDL4
xGmC2spS6EPfH35LADAG2Zb1h6OFS6FLuwgbt4i33C66fnwg.5w0bvC97WQP
zpRvtJhYd+zWxX95z+Rm9Gpgw7wXSt26wq1rZCRuU.Bovqebe8UECRNvlHo7
IWfNdUzpntHo5LdSei6.O2oAuwidJlduoiO7RZTr6PZGbdH2MQep4RMaj1eI
NUidk2+gr309pZDEGjZxUxkZhksB6lxDYBkR1.Ty8XL11DgUORdg1Lg8oWSv
5PjzUXat8IhtShBO+wgphRolkzwjlb0YXTpcE8BEdalbwz+IVQTlU8UOraNd
54CnTrS.2LfvItr0v9IQvGoMyjAH3VHs9deWzC30.V21dRJckmN796gv4P98
ueGoFvOWWjCqydFQKzCTqwsrcAOxfs1viYX2J1JlAXq8rOBtYjUNCP17csb6
Ksp6C1dI2EROp9FRCfLDI6n7cRFNe3iSOkqDxFjsUUQosgmii1WjIG+2hvpV
668Zz1sUSbhL5bz1iGRztYAuU+uPsr0Wn1fDp8IET6iDpS0EPHvV2CVDFYfZ
EVhsjTDaIRvVPJhs.KwlTz5T+ovA1dzBt8PB2LZoHgiErIETyvZhjQKajLSO
TkL.vlE.GtoWdxjpruYpwGFsr5yvZ1mooEbi0tOiSO3lgAtGndlzMFjxqC4I
GWnKd2iBiv5KCiV9xvv5LCWQK3Fq6LCjby7yXYXdF6AMl+loFe37aBg3JXSx
LvvfR8XwHTx3AySNKl2cYkP3U7tGEFg0oNhYbiikAhXpl7PB2DiuGISx8jXa
+vDvGp3pyq+Lb6uR9UBeJ9WqiiOEs4iXHLZkq.KD0bTakiztCaVuyVbWEemu
isZnbVET8pzo91EpPOKBu2SdVQm2Essi5xjUJ79PQWXLsU2cUKytmVueaTxK
g57yFxWj9eYUUlPwCjY4vkwvEUybq5GhUhUFetJ6KGn87MPpeE3wqdWmCiOG
++tRUbcAFT4OLkQJXY+xFtuTwR+qjOQ3Kp9zRSX1JPgLv3IB9gy+p7MV7SJK
tSQ.mYSSsDDHC98bTFlE2oH+N4AdI2Q1ujMA2Rv7Tpg9JTOeYv6xG8dz9jk8
R00Gi665miWPnkJufLvimfVbd5eITZiVfndQKdblhewKDXYB5lQwToHDqFdm
vUucc75xOMf6rFafuVlcBlLtRBzeGTQGkkS8iMrND6e4vKS4NxH.Y7D+nDQg
kaXsuU7ZW0+r1DrT+yjt9mkSZ8OqMFZW+ypk5edo9mWp+4k5edo9mWp+4k5e
do9mWxawk5edo9mWDFVp+4k5edQ9Xo9mWp+4k5edo9mWp+4k5edo9mWp+4k5
edo9mWp+4k5edo9mW1Z3R8OuT+yK0+7R8OuT+yK0+7R8OuT+yK0+7R8OuT+y
K0+7R8OuT+yK0+7R8OuT+yK0+7R8OuT+yK0+7R8OuT+yK0+7R8OOd0+bdc2s
T+yK0+77r9m0yi5eVoWp+YRW+y9Sa8OCd3Q25e1rT+yK0+7R8OuT+yK0+7R8
OuT+yK0+7RdKtT+yK0+7hvvR8OuT+yKxGK0+7R8OuT+yK0+7R8OuT+yK0+7R
8OuT+yK0+7R8OuT+yK0+7xVCWp+4k5edo9mWp+4k5edo9mWp+4k5edo9mWp+
4k5edo9mWp+4k5edo9mWp+4k5edo9mWp+4k5edo9mWp+4k5edo9mWp+4Qr9m
s0c2R8OuT+yyy5eNXdT+yb4R8OS55etHgZmnBflKncAPWjAsKU.8REPuTAzK
U.8REPuTAzKU.8REPuTAzKU.8REPuHLrTAzKU.8h7wREPuTAzKU.8REPuTAz
KU.8REPuTAzKU.8REPuTAzKU.8REPur0vkJfdoBnWp.5kJfdoBnWp.5kJfdo
BnWp.5kJfdoBnWp.5kJfdoBnWp.5kJfdoBnWp.5kJfdoBnWp.5kJfdoBnWp.
5kJfdLp.Zag2sTAzKU.87rBnKRCsIsDnqjKPtDz7CfTIsoienib.p6BTU3lL
vFmB30W4WB8vT.u2oZ0k6fTHafTbeqUWnpI45aoVcc8LVpU2ul0pKljOfC4T
oxuOIePGIKnWuqr1wH4CZKKTUd3HSFuKoa9R01VIMLSyjmDWuSbFH6+wU9xL
PuMDH3IofQ0Sao2hJQurI2EaISuFPxSHGoZF.yJoVurPR8R+sEcbIeun2+38
UZCNIVnBPzFBTAH8uVfGKZZzdfl5iR1wRRUzkj5SH8MfQ1kLDdHpaLzIAgsK
f8J+f6u64AyfbC150nheiYTYa0x5RFU9WnLpzLKO7oGbh4LwYupZVl7pzJyI
T8PZb9kxszJ2Uk8PGBaVlmv7YWdBy7lkIt5.U8w88fT.JyuHeUwalXzQdOPG
lT9nwG1Dj84KYWviH6BrmJHWIKUm+roH8B7JNNeykiyeI0B9qTpE3U.SrTtg
r0vfDfi62btEnHQ6U28wweJAfBWYzHNUd33xjAHNU9GaWzVeG6x3c0z4URMz
LL7mSMc9u.sRd+62hLNyLJO+Rs8j7DsgtIw1vspb3TjiT83KowFUZ8ZOOL13
p2tLoVL1EtMGLNrupQvllgEtDqf7qfETbVEXFJCMIaTHGU+Opve+7y0AW6Kx
qOtht0DE73yItU+weFkP475V8TBuTFespuC2h6j8X40DHdCS8CwCHS4zZuaN
S4p8LVxTtulYJGpCeBTNIC7u0CeZNzVZ.uWucjcVzCdLl6CxNwsfm1ZT2cQB
fFyMb9pCH8JdzMzOYuStKYcD9hUkpzvFstz2bwtQqLCHmr6m0FDVbvX0oSKO
Hs9zhEHbVg5vRTGVi5zhTSVkZ2xT6VmZ2BkaqT03CuRN+pq2QtiznvM3Istk
DHAWSlq0bIoMybsmSIMqTrhhwpJGuUh2UVF5f5EzE0qICDsYQrcCESBcAKSU
fYB3oDeQ3o.h2cikR90fkxOXBXoTeQXo.h2cikR+0fkBXlFYVJ+uHrT.Y6tw
RYdLrTU8Z7p7v7ZpkqrCvAMq67WqO4lYyYKP6YLPu3CFJlo5AlomUXlnGXlb
VgYrdfY7GHlU5h44xBl7Yo9dvQtqxt1zYq42B58.23de68Fm+10Ts6Qord0g
T1jJbgcvoHKUBHBV+m3tC9.KG9gVdaGb4McJk21IUdamVYCmXItSs71N4x1i
y4fOAylNEy9Tfetfi9cflO9XrhX9WaEGsCsYRN+q0yj4eskTZCdJ4l+09yg4
esvNon7n47u1Lel+0JfADNAI5M+qozbqwJ3B4J2RUod+JbQNcLyor14Dz0NW
aymyQzPmpaCcVhomhlV5XSeymAAKIWBC3TadMPSVRwLgkLmXBEnCAYIkyAuu
rTQtgSS2uHvv8z5+ECa+4hCMIA54.VayySBse.kj1bj9yGNRguf1bjiztqNF
8TLpPUZUGJsEsGGJpBOQ8XI91K62l9Pyd5+Q1S92gPu9uRuzOO9Tk78CcSA5
TzKuF+95SuDsud9is4Pb7g2cesn81TPJCvp65Nbmetd2GY+7+VB6PYtpCGKt
T0qD8dhA52We9s5OvcgOG2zi6s8G13lx7eRtRcBSiLIIPkaTMiB0D.iaJoxq
gJk9gFo9T3GuizTBC9G8jI3NfQWJaRNjgb2Ag5fxWlOj1G2CY31Np.204zeE
NEgeyVrzY+yWhCRnswbKgNIALAKKWzxWtDsr66D.djhV1w0uk3tHxsuvfAiq
RSMmE4Tpe3lSr.GrWjIteiN4QRl3erpZMP0xZrM1mL7qwimLwzGdjtclMeWn
j0YVM0blMOb6ZvvqNuE9Nmblcwi04lGq9eY7XMW9QtXcdHVmMyDOVsFVnqGq
jJkGrDqEOVGhLgvaN3wZ9ZLg8XUvFGYh7J2vEk726hLxfSJANE.taQkGoGoh
15XAithCaibAnCKJN54RoXxUbfXGZ1kXOMM2glX5ykBjdj.DRieobRgPNjHT
DLDZK5UFjdE8LPuR9RLY0q3OSzqjO5+npdEyz6T2+tKRnu2D6TWv33TWaDoW
W+QkKjlzpOc3CnBm4sS.khqIf7wj.J8HjWwRVvh0qgOPDYy.qW4KwT05kjOS
rdYIjFMMsdIEDLLcK5UFjdE4bX211kXxpWQMW1sMPHIqdkoOe6iWsY0ltZ6l
vvgUH7KMgG8QM90GfJmaj0ze5qNIOjzSaCeRSsBSRZH.aYzpHbcCVFTUyWOH
K5Wh0+PYJCHz31MuoI6Er3+v.lu2S+w7kl2L3ViEP61SwFZmRdzT4nZY6dhI
RBwpedQBomRHSe5LeNbWmtFxfJUWH.0f794TyHJYPfxsN9vKoydIb8mdqcEe
p4UiZjNhvMeDGeXeWwZFR0UqK0bu7WQv8Ukfc0HvJsIkklAiPhPBox3fDiUD
hbY4srZjkp7W6K4BEhO8aJKU+EaE1sQvDklhj8aaY+XLiZfxejrw2Lg8oWSv
5PbzUNjzf8oIbLE6sPYFGpJNa.VRGWzxLJo6zKCEdGL4ho+SrhnLvO79rE0Q
yrn1iPw1NeK8Kw1dHlr0ygyLKeIlpw1VSlyLCQ7ssDSHqOzSGsrgAejVL8Y8
wl0m65PBL7oMuOzxwIsENtde3tNKkavaRnhtar+lb5vG62ByOJcypTuTJU5h
xqR2fJUTDJ03PnpO2FbRnrwOv694oSCcpDcaaHYDFXaXnFLi+XQM7mATCcvX
QMLy.pAXjZLnFA2GpwkAM5UCpiKDHWiDgRjoqFEBA0GuAsLTNXU9dNGABMO9
CZcYsuPsAITe0XGYRgZejPslTPsFKKhjVfsoGfMc3r098.r4zAr08.rEzArE
XEI4zh4liEtYzBtYXYSBnEb6gDtUDCtQB1LORA1p93Ux..alOb.W94sEbk8M
SM9nLyy0Al+8XgPnoyJAScOvHdxlLdzXDV+bTzxY3LvggAtG5JgwjR6EBHQ7
3dEu6QhQnLtQrUBrVITzxCeGfia3VPKvVfkwmV9bpv5yohV9bpv5yohXNAg0
mSZwlHwZgcfdJyzYJxYlL05Zdwadj3CFwUs27bcPItoEBgMBpLYw6lZLhcOP
HCDr7GI9X5iBU5DhJIZO2nUfLkn8OiV6BShN1ZJZA2JrvMs7qTh1uRZ4niDa
vLkDyiArNVJIF8Fqik7.Zo+Fario09ljX8CSPNpMGKXyIEXKvB1hYGusTeS9
HZaFoFd9alXlmLzY.77osfVVZlOwywIomdDvILxwxgtuDe0OMBgfaJvItYDv
IAVbZ.qS7KqJokXxXv1gxAHysIEYCUdwalXNNw.SxkJbb.NEHGAbBilAwPid
dYMCPVzwzi.NIvhS2fTDfNxGMam.696Ez57.DX2mrfV6uWfcexbZsOYA18IK
n09jEnMSPqMRHvtOYNs1Ig.69MEzJRzBu9rOY5.2brwalSK8fbr1c3zxtCGq
cGFshmBGcVVQq3JywZ2gSK6NbYezeSH3FscGZo+liM9rbZEeVNqO5SHDbi0d
IiV1cXl9jsfzQ+MCscGZctILcexkQBQuwZ2gQK6NLr1cXzxtCCscGhwei0tC
iV1cXnOWPZ4OHCcQNbGAa6Gl.+eCfp0eFt8WI+JgOE+q0wwmh17QLTrikf+D
.640erK9WMW.7sTa7e+kcG1rdWF8I7Tw2o3xke340OOyqn.5ydxOu9oJiZyu
2zWt7Cq3l91EpP1qvxWFxUpDWAjskFVhq5ZUk2PgsiRx58vKbMpjlodCrAkj
N9MisM5nK08ZZiII4i1UlTVkRxyojt6gICu+k3rz9qLEDy6aIt5YI28UM6jr
ZYU6VW03i4plUVSwWV0tsUMwDHqsrpcqqZx63pV4FOzk9jyojGa3Je9JewJe
4JeEh0UnfeBj06XNML4wK++HVbc1Tc5lTobSpTCfTUsuBccCd2IswX6yEPKe
STeHHgDgyFvnHwXsaL1a.Xb4VDj6Udn+c.Ytc.zc6R63qEn20cFnA1Uf5Fu8
ue3cmpxjfAHNy2cm7K44eZa3o5ci0Ku7vT60xuiKMZuh8lcK9M5Z9L2OMeum
r6fny6h119JsGXmBlKCAPCvxzoxsxFW1Fk7RnNmV3KR+uLpqPwCjYMoWigKp
1ZdqKmvXBedlbhef1y2.812.O9UFyfeOU9MpLRAK6Wwv8kJV5ek7IBeQ067v
onDsaE64LeINs+xWUfMv3IB9gy+xIjHKtSQPBcDZEwI3PFJ34fKn3NE42IuP
0vE0E9oDDc0677kUBuKeTBOUxJe9yJsE3mtnd8OGufVKUdAYfGOAs37z+Rnz
Fs.A6ZwiyT7KdgtKSP2LJlJEgX0v6DYrsqiW2DyePCL+0+g8uH1kt1mgGYq3
+nDtwxy+ldJ1rKQadNGy9JLFUzcTFubIVAICDKnn+50kOCkaAT0kMJjip+GU
3ue945fq8E4.L2TLf2c0HCuO9fcb0e7mQITtftUOkvKkwWqvQGuzbhuSddIc
PfZXa7hxHS3o5AX54ncgeFd5rUKTde556kaU+YnZlCUZOOnWWVtYomvcr6vS
uAdcTNdP84Yb3X39Ke+xbKUMLBeyn8GOEd1g5ytCpky3T8C7ga6kSQaOrOEH
pbmoeb9O2+0UeVC9F6WezwMGe3vtMqO8Yz4nM6BqrNjvIudez6qiCii.3g6U
beQue7TDzI0J9rv8qSdFud9oSG1sqxiBtxmNtx1vOidJ7Oi1F+J3YgWoe9l5
.a3ZQc.mXG8nNvocYfeK8nNLcnxV5.udiP63CEtlO.ftYjkOGPV6To3lQVwz
hrs0tfw0+EUfRO0PmEPOrFaeCMO3VZJtx5H7EqJUogMZcoaKLxzVScYj0sUF
TVZb7rPasAgEGLVc5zxCRqOsXABmUnNrD0g0nNsH0jUo1sL0t0o1sP41JUM9
vqjyu55czXUaT3F7jV2RyUsauqcKW5U6hMXlykKw0tpSkhUTLVU43sR7txxP
GTuftndMYfnMKhsanXRnKXYpf35Mx7ThuH7T.w6twRI+ZvR4GLArTpuHrT.w
6twRo+ZvRALSiLKk+WDVJfrc2XoLOFVppdMdUyX+ZpkqLwxAMq6FFdKIkkw4
20YhY0dxY0K9fghYpdfY5YElI5AlImUXFqGXF+AhYktXdZChI0AquGbj6prq
Mc1ZpDhdOvMt22duw4ucMU6dLGVu5PJaRENjOMBsrzrRSvvLmBqFDmAefkC+
PKusCt7lNkxa6jJusSqrgSrD2oVdambY6w4bvmfYSmhYadh69vLukCz7wGi0
Lk3nDGg4GVelZnOfPpJZX93L8iR5+NKMXc3Hk1fmJn1jj1exmPfurNFG6HGN
XKdvjMZ.afFZl9orXzwvDOm5laTALfvIHoLTiRFPn42pUvUpWFeqC3ri8l7w
2JFybJqcNAcsywXjvPmpaCcVhomhlV5XS+vvEAKIGFVoBadMPSVRwLgkLmX5
wIJKobN38kkJxgQKL8b+honh+WLUmbjZXvLC0b.8b.iomE6GPIoMGo+7giT.
sGT5xQNR6t5XzSwnBUoUcnDFw5MNUw271K62l9Pyd5+Q1S92gPu9uRuzOO9T
k78qsrVq53JO5kWiee8oWh1WO+w1bHN9v6tuVzdaJHkAX0ccGtyOWu6ire9e
KgcnLW0giEWp5UhdOw.86qO+V8G3tvmia5w819CabSY9OIWoNgoQljDnxMpl
QgZBfKwYEfKPdonRoenwQ987GuizTBC9G8jI31TF05MNBt3Ojgb2Ag5fxVz7
9i8gLbaGUf65b5uBmhvuwsV8UeUNHANaVbRBXBVVtnkubIZYCn3C3SdzxNt9
sD2EQt8kz17cpyhZp4rHWPn.HmSrri8gEYh9ISHmbYh+wpp0.UKqw1XexvuF
OdxDSe3Q51Y17cgRVmY0TyY17vsqACuYTLsYd4L6hGqyMOV8+x3wZt7ibw57
PrNalIdrZMrPWOVIUJOXIVKdrNDYBg2bvi070XB6wpfMNxDUaIZUoj+dWjQF
bRIvo.vcKp7H8HUzVGKXzUbXahd.cXQwQOWJESthCD6PytD6oo4NzDSetTfz
iDfPZ7KkSJDxgDghfgPaQuxfzqnmA5UxWhIqdE+YhdEKgjr5ULSuSc+6tHg9
dSrScAiiScsQjdc8GUtPZRq9zgOfJbl2NATJtl.xGSBnziPdEKYAKVuFr0KI
aFX8JeIlpVuj7Yh0KKgznoo0KoffgoaQuxfzqHmC611tDSV8Jp4xtsABIY0q
L84ae7pMq1zUa2TmEsSgvGpmFbjwLUMCPkyMxZ5O8UmjGR5osgOooVgIIMDf
sLZUDttAKSIbOHK5Wh0+PYJCFIiNX7eHuoI6Er3+P+8ePM8GyWZdyfaMV.sa
OEancJ4QSkipks6IlHIDq94EIjdJgL8oy74vcc5ZHCpTcg.TCx6mSMinjAAJ
253CujN6kv0e5s1U7olWMpQ5HB27Qb7g8cEqYHUWstTy8pOOAag6qJA6pQfU
ZSJKMCFgDgDRkwAIFqHD4xxaY0HKU4u1WxEJDe52TVp9K1JraifA8uD1.1V1
OFynFn7GIa7MSXsiJSTzUNjzf8oIbLE6sPYFGpJNa.VRGWzxLJo6zKCEdGL4
ho+SrhnLvO79rE0Qyrn1iPw1NeK8Kw1dHlr0ygyLKeIlpw1VSlyLCQ7ssDSH
qOzSGsrgAejVL8Y8wl0m65PBfFIyzk2GZ43j1BkGIxMWJ2f2jPEc2X+M45Yi
rKUpHmOx3ITpwgPUetM3jPYief28ySmF5TI511PxHLv1vPMXF+whZ3OCnF5f
whZXlATCvH0XPMBtOTiKCZzqFTGWHPtFIBkHSWMJDBpOdCZYnbvp78bNBDZd
7Gz5xZegZCRn9pwNxjB09HgZMofZMVVDIs.aSO.a5vYq86AXyoCXq6AXKnCX
KvJRxoEyMGKbynEbyvxlDPK31CIbqHFbiDrYdjBrU8wqjA.1Le3.t7yaK3J6
alZ7QYlmqCL+6wBgPSmUBl5dfQ7jMY7nwHr94nnkyvYfCCCbOzUBiIk1KDPh
3w8Jd2iDiPYbiXqDXsRnnkG9N.G2vsfVfs.KiOs74Tg0mSEs74Tg0mSEwbBB
qOmzhMQh0B6.8TloyTjyLYp007h27HwGLhqZu445fRbSKDBaDTYxh2M0XD6d
fPFHX4OR7wzGEpzIDURzdtQq.YJQ6eFs1ElDcr0TzBtUXgaZ4WoDsekzxQGI
1fYJIlGCXcrTRL5MVGK4AzR+M1XGSq8MIw5GlfbTaNVvlSJvVfErEyNdao9l
7Qz1LRM772LwLOYny.34SaAsrzLehmiSRO8HfSXjikCceI9peZDBA2TfSbyH
fSBr3z.Vm3WVURKwjwfsCkCPlaSJxFp7h2LwbbhAljKU33.bJPNB3DFMChgF
87xZFfrnioGAbRfEmtAoH.cjOZ1NA182Kn04AHvtOYAs1eu.69j4zZexBr6S
VPq8IKPalfVajPfcexbZsSBA18aJnUjnEd8YexzAt4Xi2LmV5A4Xs6vokcGN
V6NLZEOEN5rrhVwUli0tCmV1c3x9n+lPvMZ6NzR+MGa7Y4zJ9rbVezmPH3Fq
8RFsr6vL8IaAoi9aFZ6Nz5bSX59jKiDhdi0tCiV1cXXs6vnkcGFZ6NDi+Fqc
GFsr6vPetfzxePF5hb3NB11OLA9+F.Uq+Lb6uR9UBeJ9WqiiOEs4iXnXGKA+
I.1yq+XW7uZt.3ao13+9K6NrY8tL5S3ohuSwkK+vyqedlWQAzm8jed8SUF0l
euoub4GVwM8sKTgrWgkuLjqTItBHaKMrDmMs77VCjcTRVuGdgqQkzL0afMnj
zwuYrsQGcotWSaLIIeztxjxpTRdNkzcOLY38uDmk1uygYlqdVxceUyStrpcW
V0Di4plUVSwWV0tsUM4DHqsrpcqqZp63pV4FOzk9jyojGa3JsbkVsRqW4iXY
Ep2GiodCyogAOd4+GwZqydpS2TJsaJkZ.TppsUnKjpf1nM91FeJzw2D0mARH
Q3r4KJRL12MF6M.LtbGBx8JOzOffD2N.V4Sa3qEn20MFnA1Tf5FuM2O7tSMY
Bv9Cm46tQ9k77OsM7T8lw5kWdXZ8Z42wkBsWwdytE+FcEeA2OEeumr4fny6h
119JsGzFvfwxP.vua5T4VYaKaiRdITmSK7Eo+WF0Un3AxrdzqwvEU6Lu0kSX
LgOOSNwOP64afV6afG+JaYvumJ+FUFofk8qX39REK8uR9Dgun5cd3TTh1shs
bluDm1d4qJvFX7DA+v4e4DRjE2oHHgNBch3DbHCE7bvETbmh76jWnZ3h5B+T
Bht5cd9xJg2kOJgmJYkO+Yk1A7SsXc8OGufVKUdAYfGOAs37z+RnzFs.A6Zw
iyT7KdgtKSP2LJlJEgX0v6DYrsqiW2.yew3rqNye8eX+Khcoq8Y3Q1J9OJga
r7zuomhM6RzlmywruBiQEcGkwKmShGvmgfh1qWW9LTtCPUW1nPNp9eTg+94m
qCt1WjCvbSw.oyUeL793B1wU+weFkP4LcqdJgWJiuVgiNdo2Dem77R5f.0vt
3EkQlvS0iuzyQ6B+L7zYqVn71z02K2o9yP0LGpzddPqtrbuROg6X2gmdC75n
b3f5yy3vwv8W99k4VpZXD9lQ6OdJ7rC0mcGSKmgo5G3i11Kmh1dXeJPT4NS+
37et+qq1rF7M1u9niaN9vgcaVe5ynyQa1EVYcHgSd89n2WGGFGAvC2q39hd+
3oHnQpU7Yg6Wm7Ld87SmNraWkGEbkOcbksgeF8T3eFsM9UvyBuR+7M0.1v0g
5.NwNZQcFnuxG32RKpCSCprkFvq2HzM9Pgq4y+maFY4yAj0NTJtYjULsHaac
KXbseQEnzSMzQAzCqu12PuCtkdhqrNBewpRUZXiVW51BiLsyTWFYcakAkkFG
OKzVaPXwAiUmNs7fz5SKVfvYEpCKQcXMpSKRMYUpcKSsacpcKTtsRUiO7J47
qtdG8U0FEtAOo0szaU616Z2xkd0tXCl4b4Rbsq5ToXEEiUUNdqDuqrLzA0Kn
KpWSFHZyhX6FJlD5BVlJHtdiLOk3KBOEP7tarTxuFrT9AS.Kk5KBKEP7tarT
5uFrT.yzHyR4+EgkBHa2MVJyigkppWiW0K1ulZ4JQrbPy5teg2RNYYb9cclW
VsmaV8hOXnXlpGXldVgYhdfYxYElw5AlwefXVoKlm0fXxbv56AG4tJ6ZSmsl
Ign2Cbi68s2ab9aWS0tGig0qNjxlORZnS9JKMpzDLLiovpAwYvGX4vOzxa6f
KuoSo71Noxa6zJa3DKwcpk21IW1dbNG7IX1zoX1lm3tOLya4.Me7wXMSINJw
QX7g0mgF5CHjphFFONS+jj9uyRCVGNRoM3oBpMHo8m7AD3KqiwwNxgC1hGLY
SFvFngloeHKFcLLwyot4FU.CHbBRJC0njADZ7sZEbk5ko25.N6XuIe5shwLm
xZmSPW6bLFILzo51PmkX5onokN1zOKbQvRxgYUpvlWCzjkTLSXIyIlPhdSPV
R4bv6KKUjCSVX549ESQE+uXpN4H0PBYC0b.8b.iomE6GPIoMGo+7giT.cGT5
xQNR6t5XzSwnBUoUcnDlv5MNTw271K62l9Pyd5+Q1S92gPu9uRuzOO9Tk78q
srVq5zJO5kWiee8oWh1WO+w1bHN9v6tuVzdaJHkAX0ccGtyOWu6ire9eKgcn
LW0giEWp5UhdOw.86qO+V8G3tvmia5w819CabSY9OIWoNgoQljDnxMplQgZB
fKwYEfKPdonRoenwQ987GuizTBC9G8jI31TF05MNBt3Ojgb2Ag5fxVy79i8g
LbaGUf65b5uBmhvuwsV8UeUNHANaVbRBXBVVtnkubIZYCn3C3SdzxNt9sD2E
Qt8kzt7cpyhZp4rHWPn.HmSrrS8gEYh9ISHmbYh+wpp0.UKqw1XexvuFOdxD
Se3Q51Y17cgRVmY0TyY17vsqACuYTLsYd4L6hGqyMOV8+x3wZt7ibw57PrNa
lIdrZMrPWOVIUJOXIVKdrNDYBg2bvi070XB6wpfMNxDUaIZUoj+dWjQFbRIv
o.vcKp7H8HUzVGKXzUb3Asj.fNrn3nmKkhIWwAhcnYWh8zzbGZhoOWJP5QBP
HM9kxIEB4PhPQvPnsnWYP5Uzy.8J4KwjUuh+LQuhkPRV8Jlo2ot+cWjPeuI1
otfwwot1HRut9iJWHMoUe5vGPENyam.JEWS.4iIAT5QHuhkrfEqWC15kjMCr
dkuDSUqWR9Lw5kkPZzzz5kTPvvzsnWYP5UjygcaaWhIqdE0bY21.gjr5Ul97
sOd0lUa5psapyh1oP3C0SCNxXlplAnx4FYM8m9pSxCI8z1vmzTqvjjFBvVFs
JBW2fkoDtGjE8Kw5enLkAijQGL9Oj2zj8BV7en+9Onl9i4KMuYvsFKf1smhM
zNk7noxQ0x18DSjDhU+7hDROkPl9zY9b3tNcMjAUptP.pA48yolQTxf.kac7
gWRm8R35O8V6J9TyqF0HcDga9HN9v9th0LjpqVWp4d0Gmfsv8Ukfc0HvJsIk
klAiPhPBox3fDiUDhbY4srZjkp7W6K4BEhO8aJKU+EaE1sQvf9WBa.aK6GiY
TCT9ijM9lIr1IkIJ5JGRZv9zDNlh8VnLiCUEmM.KoiKZYFkzc5kgBuClbwz+
IVQTF3Gde1h5nYVT6QnXamuk9kXaODS154vYlkuDS0XaqIyYlgH91VhIj0G5
oiV1vfORKl9r9Xy5yccHAPijY5x6CsbbRagxiD4lKkavaRnhtar+lb8rQ1kJ
UjyGY7DJ03PnpO2FbRnrwOv694oSCcpDcaaHYDFXaXnFLi+XQM7mATCcvXQM
Ly.pAXjZLnFA2GpwkAM5UCpiKDHWiDgRjoqFEBA0GuAsLTNXU9dNGABMO9CZ
cYsuPsAITe0XGYRgZejPslTPsFKKhjVfsoGfMc3r098.r4zAr08.rEzArEXE
I4zh4liEtYzBtYXYSBnEb6gDtUDCtQB1LORA1p93Ux..alOb.W94sEbk8MSM
9nLyy0Al+8XgPnoyJAScOvHdxlLdzXDV+bTzxY3LvggAtG5JgwjR6EBHQ73d
Eu6QhQnLtQrUBrVITzxCeGfia3VPKvVfkwmV9bpv5yohV9bpv5yohXNAg0mS
ZwlHwZgcfdJyzYJxYlL05Zdwadj3CFwUs27bcPItoEBgMBpLYw6lZLhcOPHC
Dr7GI9X5iBU5DhJIZO2nUfLkn8OiV6BShN1ZJZA2JrvMs7qTh1uRZ4niDavL
kDyiArNVJIF8Fqik7.Zo+Fario09ljX8CSPNpMGKXyIEXKvB1hYGusTeS9HZ
aFoFd9alXlmLzY.77osfVVZlOwywIomdDvILxwxgtuDe0OMBgfaJvItYDvIA
VbZ.qS7KqJokXxXv1gxAHysIEYCUdwalXNNw.SxkJbb.NEHGAbBilAwPiddY
MCPVzwzi.NIvhS2fTDfNxGMam.696Ez57.DX2mrfV6uWfcexbZsOYA18IKn0
9jEnMSPqMRHvtOYNs1Ig.69MEzJRzBu9rOY5.2brwalSK8fbr1c3zxtCGqcG
FshmBGcVVQq3JywZ2gSK6NbYezeSH3FscGZo+liM9rbZEeVNqO5SHDbi0dIi
V1cXl9jsfzQ+MCscGZctILcexkQBQuwZ2gQK6NLr1cXzxtCCscGhwei0tCiV
1cXnOWPZ4OHCcQNbGAa6Gl.+eCfp0eFt8WI+JgOE+q0wwmh17QLTrikf+D.6
40erK9WMW.7sTa7e+kcG1rdWF8I7Tw2o3xke340OOyqn.5ydxOu9oJiZyu2z
Wt7Cq3l91EpP1qvxWFxUpDWAjskFVhy9FfsGmYm54x58vKbMpjlodCrAkjN9
MisM5nK08ZZiII4i1UlTVkRxyojt6gICu+k3rz9c1d0c0yRt6qZdrkUs6xpl
bLW0x6mf7kUsaaUSMAxZKqZ25pl9NtpUtwCcoO4bJ4wFtRoWo7WoLqJZuZss
tBE7SfrdGyogIOd4+GwhqylpS2jJe2jJ0.HUU6qPWnUl1nMfgElBZ4ah5CAI
jHb1.FEIFabiwdC.iK2hfb10aBfIdCj41AP2sKsiuVfdW2YfFXWApa7N39g2
cpJia6TqLe2cxujm+osgmp2MVu7xCSsWK+Ntzn8J1a1s32Xq4qneqeGz78dx
tChNuKZaqqzLfqlCykg.nAXY5T4VYiKaiRdITmSK7Eo+WF0Un3AxrlzqwvEU
aMu0kSXLgOOSNwOP64afd6afG+JiYvumJ+FUFofk8qX39REK8uR9Dgun5cd3
TTh1sh8bluDm1e4qJvFX7DA+v4e4DRjE2oHHgNBsh3DbHCE7bvETbmh76jWn
Z3h5B+TBht5cd9xJg2kOJgmJYkO+Yk1B78jt943EzZoxKHC73InEmm9WBk1n
EHXWKdblhewKzcYB5lQwToHDqFdmHiscc75lX9YMv7W+G1+hXW5ZeFdjsh+i
R3FKO+a5oXytDs44bL6qvXTQ2QY7x4zUD9VAE8Wut7YnbKfptrQgbT8+nB+8
yOWGbsuHGf4lh9ZuqFY38wGriq9i+LJgx42s5oDdoL9ZEN53klS7cxyKoCBT
CaiWTFYBOUO.SOGsK7yvSmsZgx6SWeubq5OCUy77P64A85xxMK8DticGd5Mv
qixwCpOOiCGC2e46WlaopgQ3aFs+3ovyNTe1cPsbFmpefObaubJZ6g8o.Qk6
L8iy+49ut5yZv2X+5iNt43CG1sY8oOiNGsYWXk0gDN406idecbXbD.Obuh6K
58imhfNoVwmEtecxy30yOc5vtcUdTvU9zwU1F9YzSg+Yz13WAOK7J8y2TGXC
WKpC3D6nG0YfFKefeK8nNLcnxV5.udiP63CEtlO.ftYjkOGPV6To3lQVwzhr
s0tfw0+EUfRO0PmEPOrFaeCMO3VZJtx5H7EqJUogMZcoaKLxzVScYj0sUFTV
Zb7rPasAgEGLVc5zxCRqOsXABmUnNrD0g0nNsH0jUo1sL0t0o1sP41JUM9vq
jyu55czXUaT3F7jV2RyUsauqcKW5U6hMXlykKw0tpSkhUTLVU43sR7txxPGT
uftndMYfnMKhsanXRnKXYpfsXLx7ThuH7T.w6twRI+ZvR4GLArTpuHrT.w6t
wRo+ZvRALSiLKk+WDVJfrc2XoLOFVppdMdUyX+ZpkqLwxAMq6FFdKIkkw420
YhY0dxY0K9fghYpdfY5YElI5AlImUXFqGXF+AhYktXdZChI0AquGbj6prqMc
1ZpDhdOvMt22duw4ucMU6dLGVu5PJaLSCfLXSKKMqzDLLyovpAwYvGX4vOzx
a6fKuoSo71Noxa6zJa3DKwcpk21IW1dbNG7IX1zoX1lm3tOLya4.Me7wXMSI
NJwQX9g0moF5CHjphFlONS+nj9uyRCVGNRoM3oBpMIo8m7ID3KqiwwNxgC1h
GLYiFvFngloeJKFcLLwyot4FU.CHbBRJC0njADZ9sZEbk5kw25.N6XuIe7sh
wLmxZmSPW6bLFILzo51PmkX5onokN1zOLbQvRxggUpvlWCzjkTLSXIyIldbh
xRJmCdeYohbXzBSO2uXJp3+ES0IGoFFLyPMGPOGvX5Yw9ATRZyQ5Oe3HEP6A
ktbjiztqNF8TLpPUZUGJgQrdiSU7Mu8x9soOzrm9ej8j+cHzq+qzK8yiOUIe
+ZKq0pNtxid4032We5kn80yerMGhiO7t6qEs2lBRY.VcW2g67y069H6m+2RX
GJyUc3Xwkpdkn2SLP+95yuU+AtK743ldbus+vF2Tl+SxUpSXZjIIApbipYTn
l.3RbVA3BjWJpT5GZbjeO+w6HMkvf+QOYBtMkQsdiifK9CYH2cPnNnrEMu+X
eHC21QE3tNm9qvoH7abqUe0WkCRfylEmj.lfkkKZ4KWhV1.J9.9jGsriqeKw
cQjaeIsMem5rnlZNKxEDJ.x4DK6XeXQlnexDxIWl3erpZMP0xZrM1mL7qwim
LwzGdjtclMeWnj0YVM0blMOb6ZvvaFESalWNyt3w5byiU+uLdrlK+HWrNODq
ylYhGqVCKz0iURkxCVh0hGqCQlP3MG7XMeMlvdrJXiiLQ0VhVUJ4u2EYjAmT
BbJ.b2hJOROREs0wBFcEGdPKI.nCKJN54RoXxUbfXGZ1kXOMM2glX5ykBjdj
.DRieobRgPNjHTDLDZK5UFjdE8LPuR9RLY0q3OSzqXIjjUuhY5cp6e2EIz2a
hcpKXbbpqMhzqq+nxERSZ0mN7ATgy71IfRw0DP9XR.kdDxqXIKXw50fsdIYy
.qW4KwT05kjOSrdYIjFMMsdIEDLLcK5UFjdE4bX211kXxpWQMW1sMPHIqdko
Oe6iWsY0ltZ6l5rncZmbMBjUkTlplAnx4FYM8m9pSxCI8z1vmzTqvjjFBvVF
sJBW2fkoDtGjE8Kw5enLkAijQGL9Oj2zj8BV7en+9Onl9i4KMuYvsFKf1smh
MzNk7noxQ0x18DSjDhU+7hDROkPl9zY9b3tNcMjAUptP.pA48yolQTxf.kac
7gWRm8R35O8V6J9TyqF0HcDga9HN9v9th0LjpqVWp4d0mmfsv8Ukfc0HvJsI
kklAiPhPBox3fDiUDhbY4srZjkp7W6K4BEhO8aJKU+EaE1sQvf9WBa.aK6Gi
YTCT9ijM9lIr1QkIJ5JGRZv9zDNlh8VnLiCUEmM.KoiKZYFkzc5kgBuClbwz
+IVQTF3Gde1h5nYVT6QnXamuk9kXaODS154vYlkuDS0XaqIyYlgH91VhIj0G
5oiV1vfORKl9r9Xy5yccHAPijY5x6CsbbRagxiD4lKkavaRnhtar+lb8rQ1k
JUjyGY7DJ03PnpO2FbRnrwOv694oSCcpDcaaHYDFXaXnFLi+XQM7mATCcvXQ
MLy.pAXjZLnFA2GpwkAM5UCpiKDHWiDgRjoqFEBA0GuAsLTNXU9dNGABMO9C
ZcYsuPsAITe0XGYRgZejPslTPsFKKhjVfsoGfMc3r098.r4zAr08.rEzArEX
EI4zh4liEtYzBtYXYSBnEb6gDtUDCtQB1LORA1p93Ux..alOb.W94sEbk8MS
M9nLyy0Al+8XgPnoyJAScOvHdxlLdzXDV+bTzxY3LvggAtG5JgwjR6EBHQ73
dEu6QhQnLtQrUBrVITzxCeGfia3VPKvVfkwmV9bpv5yohV9bpv5yohXNAg0m
SZwlHwZgcfdJyzYJxYlL05Zdwadj3CFwUs27bcPItoEBgMBpLYw6lZLhcOPH
CDr7GI9X5iBU5DhJIZO2nUfLkn8OiV6BShN1ZJZA2JrvMs7qTh1uRZ4niDav
LkDyiArNVJIF8Fqik7.Zo+Fario09ljX8CSPNpMGKXyIEXKvB1hYGusTeS9H
ZaFoFd9alXlmLzY.77osfVVZlOwywIomdDvILxwxgtuDe0OMBgfaJvItYDvI
AVbZ.qS7KqJokXxXv1gxAHysIEYCUdwalXNNw.SxkJbb.NEHGAbBilAwPidd
YMCPVzwzi.NIvhS2fTDfNxGMam.696Ez57.DX2mrfV6uWfcexbZsOYA18IKn
09jEnMSPqMRHvtOYNs1Ig.69MEzJRzBu9rOY5.2brwalSK8fbr1c3zxtCGqc
GFshmBGcVVQq3JywZ2gSK6NbYezeSH3FscGZo+liM9rbZEeVNqO5SHDbi0dI
iV1cXl9jsfzQ+MCscGZctILcexkQBQuwZ2gQK6NLr1cXzxtCCscGhwei0tCi
V1cXnOWPZ4OHCcQNbGAa6Gl.+eCfp0eFt8WI+JgOE+q0wwmh17QLTrikf+D.
640erK9WMW.7sTa7e+kcG1rdWF8I7Tw2o3xke340OOyqn.5ydxOu9oJiZyu2
zWt7Cq3l91EpP1qvxWFxUpDWAjskFVhyJ.WHgVEfcTRVuGdgqQkzL0afMnjz
wuYrsQGcotWSaLIIeztxjxpTRdNkzcOLY38uDmk1uyNylqdVx8dUiEXVV0tK
qZpQbUKWVSwWV0tsUM8DHqsrpcqqZ92wUsxMdnK8ImSIO1vURyJYvJk2phFx
aaqqPA+DHq2wbZXxiW9+Qr35ro5zMox3lToF.opZeE5BsxuMMU91tRNzx2D0
GBRHQ3rALJRLNvMF6M.LtbKBx8JOzjofL21xFj1wWKPuq6LPCrq.0IdWz45t
C3c2pxrZuX9t6jeIO+SaCOUuard4kGlZuV9cboQ6Ur2rawuwVyWQOs6Nn468
jcGDcdWz1VWoCf5IEFKCAP+uxzotsx1V1Fk7RnNmT3KR+uLhqPwCjY8nWigK
p1YdqKlvXBedlXhef1y2.s12.O9U1xfeOU9MpLRAK6Wwv8kJV5ek7IBeQ067
vonDkaEa4LeENs8xWUdMv3IB9gy+xIjHKtSQPBcD5DwI3PFJ34fIn3NE42Iu
PyvEsE9oDDc0677kUBuKeTBKUxBe9yJsC36Ic8ywKn0RkWPF3wSPKNO8uDJs
QKPvsV73LE+hWn6xDzMihoRQHVM7NQDa6530Mw6yaf2u9Or+Eotz09L7HaE+
GkvMVd52zSolcIJyy4X1Wgwnhpix3UKcB0fh1qWWtLTtCPUW1nPNp9eTg+94
mqCt1WjCwZiv8hA694B1wU+weFkP4zcpcxZFVovQFuzZhuS9cIcPeZXS7hx3
R3o5gW54ncgeFd5rUITdW556kaT+YnZl6TZOOnSWVtUomvbr6vSuA9bTNZP8
4Yb3X39Ke+xLKUMKBeyn8GOEd1g1ytCokynT8C7Aa6kSQaOrOEHpbmoeb9O2
+0UWVC9F6WezwMGe3vtMqO8Yz4nM6BqrNjvHudez6qiCii.3g6UbeQue7TDz
G0J9rv8qSdFud9oSG1sqxiBtxmNtx1vOidJ7Oi1F+J3WgWoe9l5+Z3ZPc.mX
GcnNCzV4C7aoC0go+T1R+20aDZFenv07w+yMir74.xZmIE2LxJlVjsslELtt
unBT5oF5j.5g0V6an0A2RKwUVGguXUoJMrQqKcagQl1XpKirtsxfxRiimEZq
MHr3fwpSmVdPZ8oEKP3rB0gknNrF0oEolrJ0tko1sN0tEJ2VopwGdkb9UWui
1pZiB2fiz5VZspc6bsa4RuZWrAybt7Ht1UcpTrhhwpJGuUh2UVF5f5EzE0qI
CDsYQrcCESBcAKSEDUuQlmR7EgmBHd2MVJ4WCVJ+fIfkR8EgkBHd2MVJ8WCV
JfYZjYo7+hvRAjs6FKk4wvRU0qwqZE6WSsbkGVNnYc2tvaIkrLN+tNSKq1SM
qdwGLTLS0CLSOqvLQOvL4rByX8.y3OPLqzEySZPLINX88fibWkcsoyVSjPz6
Atw8916MN+sqoZ2iov5UGQYSpvgyiVnkklTZBFloTX0f3L3yqb3mY4sctk2z
gTdaGT4scXkMbfk3Nzxa6fKaONmC9.La5PLaySb2mk4sbdlO9XrloDGk3HL8
v5yLC8ADRUQCSGmoePR+2YoAqCGozF7TA0liz9S97A7k0w3XG4vAawClrACX
CzPyzOiEiNFl34T2biJfADNAIkgZTx.BM8VsBtR8xvac.mcr2jO7VwXlSYsy
InqcNFiDF5TcanyRL8TzzRGa5GEtHXI4vnJUXyqAZxRJlIrj4DSONQYIkyAu
urTQNLXgom6WLEU7+ho5jiTCikYnhCnmCXL8rX+.JIs4H8mObjBn4fRWNxQZ
2UGidJFUnJspCkv.VuwYJ9l2dY+1zGZ1S+Oxdx+ND50+U5k94wmpjuesk0ZU
GV4Qu7Z76qO8Rz954O1lCwwGd280h1aSAoL.qtq6vc945cej8y+aIrCk4pNb
r3RUuRz6IFnee842p+.2E9bbSOt21eXiaJy+I4J0ILMxjj.UtQ0LJTS.bINq
.bAxKEUJ8CMNxum+3cjlRXv+nmLA2lxnVuwQvE+gLj6NHTFT1Rl2erOjga6n
BbWlS+U3TD9Mt0pu5qxAIvYyhSR.SvxxEs7kKQKa.Ee.exiV1w0uk3tHxsuj
1juScVTSMmE4BBE.4bhkcnOrHSzOYB4jKS7OVUsFnZYM1F6SF903wSlX5COR
2NyluKTx5LqlZNylGtcMX3MihoMyKmYW7Xct4wp+WFOVykejKVmGh0YyLwiU
qgE55wJoR4AKwZwi0gHSH7lCdrluFSXOVErwQlnZCQqJk726hLxfSJANE.ta
QkGoGoh15XAithCOnkD.zgEEG8boTL4JNPrCM6Rrmll6PSL84RAROR.BowuT
NoPHGRDJBFBsE8JCRuhdFnWIeIlr5U7mI5UrDRxpWwL8N08u6hD56MwN0ELN
N00FQ500eT4BoIs5SG9.pvYd6DPo3ZBHeLIfROB4UrjErX8ZvVujrYf0q7kX
pZ8RxmIVurDRillVujBBFltE8JCRuhbNraa6RLY0qnlK61FHjjUuxzmu8wq1
rZSWscSneWKD9P8zfiLlopY.pbtQVS+ou5j7PROsM7IM0JLIog.rkQqhv0MX
YJg6wXQ+Rr9GJSYvHYzAi+C4MMYufE+G5u+Cpo+X9RyaFbqwBnc6oXCsSIOZ
pbTsrcOwDIgX0OuHgzSIjoOclOGtqSWCYPkpKDfZPd+bpYDkLHP4VGe3kzIu
Dt9Su0thO07pQMRGQ3lOhiOruqXMCo5p0kZtW8oIXKbeUIXWM.rRaRYoYvHj
HjPpLNHwXEgHWVdKqFYoJ+09RtPg3S+lxR0ewVgcaDLn+kvFv1x9wXF0.k+H
YiuYBqcPYhhtxgjFrOMgioXuEJy3PUwYCvR53hVlQIcmdYnv6fIWL8ehUDkA
9g2msnNZlE0dDJ114aoeI11CwjsdNblY4KwTM11ZxblYHhuskXBY8gd5nkML
3izhoOqO1r9bWGR.zHYlt79PKGmzVn7.Qt4R4F7lDpn6F6uIWOYjcoRE4zQF
OgRMNDp5ysAmDJa7C7ted5zPmJQ21FRFgA1FFpAy3OVTC+Y.0PGLVTCyLfZ.
FoFCpQv8gZbYPid0f53BAx0HQnDY5pQgPP8waPKCkCVkumyQfPyi+fVWV6KT
aPB0WM1QlTn1GITqIETqwxhHoEXa5AXSGNaseO.aNc.acO.aAc.aAVQRNsXt
4XgaFsfaFV1j.ZA2dHgaEwfajfMyiTfspOdkL.vl4CGvkedaAWYeyTiOJy7b
cf4eOVHDZ5rRvT2CLhmrIiGMFg0OGEsbFNCbXXf6gtRXLozdg.RDOtWw6djX
DJiaDak.qUBEs7v2A33FtEzBrEXY7okOmJr9bpnkOmJr9bpHlSPX84jVrIRr
VXGnmxLclhblISstlW7lGI9fQbU6MOWGThaZgPXifJSV7toFiX2CDx.AK+Qh
Ol9nPkNgnRh1yMZEHSIZ+yn0tvjnislhVvsBKbSK+Jkn8qjVN5HwFLSIw7X.
qikRhQuw5XIOfV5uwF6XZsuIIV+vDjiZywB1bRA1BrfsX1waK02jOh1lQpgm
+lIl4ICcF.OeZKnkkl4S7bbR5oGAbBibrbn6KwW8SiPH3lBbhaFAbRfEmFv5
D+xpRZIlLFrcnb.xbaRQ1PkW7lIliSLvjboBGGfSAxQ.mvnYPLznmWVy.jEc
L8HfSBr3zMHEAni7Qy1Ivt+dAsNO.A18IKn096EX2mLmV6SVfcexBZsOYAZy
DzZiDBr6SlSqcRHvteSAshDsvqO6SlNvMGa7l4zROHGqcGNsr6vwZ2gQq3ov
QmkUzJtxbr1c3zxtCW1G82DBtQa2gV5u4XiOKmVwmky5i9DBA2XsWxnkcGlo
OYKHczeyPa2gVmaBS2mbYjPzar1cXzxtCCqcGFsr6vPa2gX72Xs6vnkcGF5y
EjV9CxPWjC2Qv19gIv+2.nZ8mga+UxuR3Sw+Zcb7onMeDCE6XI3OAvdd8G6h
+UyE.eK0F+2eY2gMq2kQeBOU7cJtb4Gdd8yy7JJf9rm7yqepxn176M8kK+vJ
toucgJj8Jr7kgbkJwU.Yaogk3rtVyGeZ1QIY8d3EtFURyTuA1fRRG+lw1Fcz
k5dMswjj7Q6JSJqRI44TR28vjg2+RbVZ+NKqeW8rj68pVfZYQ6trnoGwEsbQ
MEeYU61V07GeQskEsacQybGWzJ21gtzkbNk7XCWI8VIYqj7UEC7hVVVgp8IP
Vuc4zvXGu7+iXs0YG0oaJUfaJkZ.TppMUnKjJca5or86MEzu2D0m.RHQ3roK
JNL12yMF6M.Ltb+Ax4BOzU+fr1N.vzzt8ZA1ccWAZfcDntQa18Cs6TOlRpyO
Gamcwujm+osgmp2IVu7xCSoWK+Ntzm8J1a1sz2Xq2yme+z68dxNChNuKZa6q
zvz4z1TnCflekoScakMs.S9dcNsvWj9eYTWghGHyZPuFCWTss7VWNgwD97L4
D+.smuA5quAd7qLkA+dp7aTYjBV1uhg6KUrz+J4SD9hp24gSQIJ2J1uY9RbZ
ukup.afwSD7Cm+kSHQVbmh.Ny1FhSvgLTvyAWPwcJxuSdgpgKpK7SIH5p244
KqDdW9nDdpjU97mUZ6u2S55miWPqkJufLvimfVbd5eITZiVffcs3wYJ9EuP2
kInaFESkhPrZ3chL110wqah4Wz.ye8eX+Khcoq8Y3Q1J9OJgar7buomhM6Rz
lmywruBiQEcGkwKWhUFnS5amZ19c6xP41+TcYiB4n5+QE96metN3ZeQNDyMR
2KFr6mGXGW8G+YTBkSgP8DLszTJbzwKMl36jiWRGDnF1BunLxDdpdvkdNZW3
mgmNa0Bk2it9d41zeFplgvZOOnOWVtQomvcr6vSuAdcTNVP84Yb3X39Ke+xb
KUMLBeyn8GOEd1g5ytCnkyXT8C7gZ6kSQaOrOEHpbmoeb9O2+0UOVC9F6Wez
wMGe3vtMqO8Yz4nM6BqrNjvIudez6qiCii.3g6UbeQue7TDzE0J9rv8qSdFu
d9oSG1sqxiBtxmNtx1vOidJ7Oi1F+J3YgWoe9l59Z3ZOc.mXG8mNP4jLvuk9
SGltSYKceWuQnU7gBWyG9O2LxxmCHqchTbyHqXZQ11ZUv358hJPomZnyAnGV
SsugFGbKMDWYcD9hUkpzvFstzsEFYZaotLx51JCJKMNdVns1fvhCFqNcZ4Ao
0mVr.gyJTGVh5vZTmVjZxpT6VlZ25T6VnbakpFe3Ux4Wc8NZppMJbCdRqaow
p1s20tkK8pcwFLy4xk3ZW0oRwJJFqpb7VIdWYYnCpWPWTulLPzlEw1MTLIzE
rLUPb8FYdJwWDdJf3c2XojeMXo7Cl.VJ0WDVJf3c2XozeMXo.loQlkx+KBKE
P1tarTlGCKUUuFupQreM0xUVX4fl0cyBukDxx3765LorZOwr5EevPwLUOvL8
rByD8.yjyJLi0CLi+.wrRWLOkAwj1f02CNxcU10lNaMMBQuG3F26au2372tl
pcOlAqWcHkMoBGxlFgVVZNoIXXlQgUChyfOvxgenk21AWdSmR4scRk21oU1v
IVh6TKusStr83bN3SvroSwrMOwceXl2xAZ93iwZlRbThivrCqOSLzGPHUEML
abl9wH8emkFrNbjRavSETaJR6O4SGvWVGiicjCGrEOXxFKfMPCMS+DVL5XXh
mScyMp.FP3DjTFpQICHzra0J3ZyUtkQ2Z+N6XuIezshwLmxZmSPW6bLFILzo
51PmkX5onokN1zOHbQvRxgAUpvlWCzjkTLSXIyIldbhxRJmCdeYohbXrBSO2
uXJp3+ES0IGoFFJyPMGPOGvX5Yw9ATRZyQ5Oe3HEPqAktbjiztqNF8TLpPUZ
UGJgwqdiST7Mu8x9soOzrm9ej8j+cHzq+qzK8yiOUIe+ZKq0pNpxid4032We
5kn80yerMGhiO7t6qEs2lBRY.VcW2g67y069H6m+2RXGJyUc3Xwkpdkn2SLP
+95yuU+AtK743ldbus+vF2Tl+SxUpSXZjIIApbipYTnl.3RbVA3BjWJpT5GZ
bjeO+w6HMkvf+QOYBtMkQsdiifK9CYH2cPnNnrULu+XeHC21QE3tNm9qvoH7
abqUe0WkCRfylEmj.lfkkKZ4KWhV1.J9.9jGsriqeKwcQjaeIsEem5rnlZNK
xEDJ.x4DK6HeXQlnexDxIWl3erpZMP0xZrM1mL7qwimLwzGdjtclMeWnj0YV
M0blMOb6ZvvaFESalWNyt3w5byiU+uLdrlK+HWrNODqylYhGqVCKz0iURkxC
Vh0hGqCQlP3MG7XMeMlvdrJXiiLQ0NhVUJ4u2EYz16WfSAf6VT4Q5QpnsNVv
nq3.ZjKLfNrn3nmKkhIWwAhcnYWh8zzbGZhoOWJP5QBPHM9kxIEB4PhPQvPn
snWYP5Uzy.8J4KwjUuh+LQuhkPRV8Jlo2ot+cWjPeuI1otfwwot1HRut9iJW
HMoUe5vGPENyam.JEWS.4iIAT5QHuhkPeMbw50frdIYy.qW4KwT05kjOSrdY
IjFMMsdIEDLLcK5UFjdE4bX211kXxpWQMW1sMPHIqdkoOe6iWsY0ltZ6lvbf
PHf90LxpRJSUy.T4birl9Se0I4gjdZa3SZpUXRRCAXKiVEgqavxTB2Cxh9kX
8OTlxfQxnCF+GxaZxdAK9Oze+GTS+w7kl2L3ViEP61SwFZmRdzT4nZY6dhIR
BwpedQBomRHSe5LeNbWmtFxfJU2NbbD794TyHJYPfxsN9vKoydIb8mdqcEep
4UiZjNhvMeDGeXeWwZFR0UqK0bu5SSvV39pRvtZDXk1jxRyfQHQHgTYbPhwJ
BQtr7VVMxRU9q8kbgBwm9Mkkp+hsB61HXP+KgMfsk8iwLpAJ+QxFeyDV6fxD
EckCIMXeZBGSwdKTlwgphyFfkzwEsLiR5N8xPg2AStX5+DqHJC7CuOaQczLK
p8HTrsy2R+RrsGhIa8b3LyxWhoZrs0j4LyPDeaKwDx5C8zQKaXvGoESeVerY
84tNj.nQxLc48gVNNosP4IhbykxM3MITQ2M1eStd1H6RkJx4iLdBkZbHT0ma
CNIT13G3c+7zogNUhtsMjLBCrMLTClwernF9y.pgNXrnFlY.0.LRMFTif6C0
3xfF8pA0wEBjqQhPIxzUiBgf5i2fVFJGrJeOmi.glG+Astr1Wn1fDpuZriLo
PsORnVSJnVikEQRKv1zCvlNb1Z+d.1b5.15d.1B5.1BrhjbZwbywB2LZA2Lr
rIAzBt8PB2JhA2HAalGo.aUe7JY.fMyGNfK+71Btx9loFeTl445.y+drPHzz
YkfotGXDOYSFOZLBqeNJZ4LbF3vv.2CckvXRo8BAjHdbuh28HwHTF2H1JAVq
DJZ4guCvwMbKnEXKvx3SKeNUX84TQKeNUX84TQLmfv5yIsXSjXsvNPOkY5LE
4LSlZcMu3MOR7Ai3p1adtNnD2zBgvFAUlr3cSMFwtGHjABV9iDeL8QgJcBQk
DsmazJPlRz9mQqcgIQGaMEsfaEV3lV9UJQ6WIsbzQhMXlRh4w.VGKkDidi0w
Rd.szeiM1wzZeSRr9gIHG0liEr4jBrEXAawri2VpuIeDsMiTCO+MSLySF5L.
d9zVPKKMym343jzSOB3DF4X4P2Whu5mFgPvME3D2LB3j.KNMf0I9kUkzRLYL
X6P4.j41jhrgJu3MSLGmXfI4RENN.mBji.NgQyfXnQOurlAHK5X5Q.mDXwoa
PJBPG4ilsSfc+8BZcd.Br6SVPq82KvtOYNs1mr.69jEzZexBzlIn0FIDX2mL
mV6jPfc+lBZEIZgWe1mLcfaN13MyokdPNV6NbZY2gi0tCiVwSgiNKqnUbk4X
s6vokcGtrO5uIDbi1tCszeywFeVNshOKm0G8IDBtwZujQK6NLSexVP5n+lg1
tCsN2DltO4xHgn2Xs6vnkcGFV6NLZY2gg1tCw3uwZ2gQK6NLzmKHs7GjgtHG
tifs8CSf+uAP05OC29qjekvmh+0533SQa9HFJ1wRveBf875O1E+qlK.9VpM9
u+xtCaVuKi9Ddp36Tb4xO775mm4UT.8YO4mW+TkQs42a5KW9gUbSe6BUH6UX
4KC4JUhq.x1RCKwUcspfRkmGXixY8d3EtFURyTuA1fRRG+lw1Fczk5dMswjj
7Q6JSJqRI44TR28vjg2+RbVZ+kKaW+7Bb2UOK4tup44urpcWV07GyUMqrls7
UVV0F7plYBj0VV0t0Usf63pV4FOzk9jyojGa3Je8Je+U9lUW9EaYcEFntAx5
cLmFl73k+eDKtNapNcRpLdtIUpAPpp1WgtPqTsQaLPy7DZpPbQ8gfDRDNa.i
hDiYtwXuAfwkaQPtW4sUaWFdE.c2tzN9ZA5ccmAZfcEntwa98Cu6TUlzNovg
1A40cxujm+osgmp2MVu7xCSsWK+Ntzn8J1a1s32Xq4yHteZ9dOY2AQm2Ess8
UZOYoFCc.z.rLcpbqrwksQIuDpyoE9hz+Ki5JT7.YVS50X3hpsl25xILlvmm
Im3Gn87MPu8MviekwL32SkeiJiTvx9ULbeohk9WIehvWT8NObJJQ6VwdNyWh
S6u7UEXCLdhfe37ubBIxh6TDvY1VQbBNjgBdN3BJtSQ9cxKTMbQcgeJAQW8N
OeYkv6xGkvSkrxm+rRaA9oKpW+ywKn0RkWPF3wSPKNO8uDJsQKPvtV73LE+h
Wn6xDzMihoRQHVM7NQFa6530Mw7Kaf4u9Or+Ewtz09L7HaE+GkvMVd92zSwl
cIZyy4X1Wgwnhtix3kKwp7baxjq5rKeFJ2BnpKaTHGU+Opve+7y0AW6KxgXt
Q4dwfc+7A63p+3OiRnbRDpmfIllRgiNdo4Dem77R5f.0v13EkQlvS0CvzyQ6
B+L7zYqVn79z02K2p9yP0LDV64A85xxMK8DticGd5MvqixwCpOOiCGC2e46W
laopgQ3aFs+3ovyNTe1cPsbFmpefObaubJZ6g8o.Qk6L8iy+49ut5yZv2X+5
iNt43CG1sY8oOiNGsYWXk0gDN406idecbXbD.Obuh6K58imhfNoVwmEtecxy
30yOc5vtcUdTvU9zwU1F9YzSg+Yz13WAOK7J8y2TGXCWKpC3D6nG0ANsKC7a
oG0goCU1RG30aDZGenv07A.zMir74.xZmJE2LxJlVjss1ELt9unBT5oF5r.5
g0X6an4A2RSwUVGguXUoJMrQqKcagQl1ZpKirtsxfxRiimEZqMHr3fwpSmVd
PZ8oEKP3rB0gknNrF0oEolrJ0tko1sN0tEJ2VopwGdkb9UWuiFqZiB2fmz5V
Ztpc6csa4RuZWrAybtbIt1UcpTrhhwpJGuUh2UVF5f5EzE0qICDsYQrcCESB
cAKSEDWuQlmR7EgmBHd2MVJ4WCVJ+fIfkR8EgkBHd2MVJ8WCVJfYZjYo7+hv
RAjs6FKk4wvRU0qwqZF6WSsbkIVNnYc2vvaIorLN+tNSLq1SNqdwGLTLS0CL
SOqvLQOvL4rByX8.y3OPLqzEySaPLoNX88fibWkcsoyVSkPz6Atw8916MN+s
qoZ2i4v5UGRYSpvg7oQnkklUZBFl4TX0f3L3Crb3GZ4scvk2zoTdamT4scZk
Mbhk3N0xa6jKaONmC9DLa5TLaySb2Gl4sbflO9XrloDGk3HL+v5yTC8ADRUQ
CyGmoeTR+2YoAqCGozF7TA0ljz9S9DB7k0w3XG41rQKXxFMfMPCMS+TVL5XX
hmScyMB45FCNAIkgZTx.BM+VsBtR8x3ac.mcr2jO9VwXlSYsyInqcNFiDF5T
canyRL8TzzRGa5GFtHXI4vvJUXyqAZxRJlIrj4DSONQYIkyAuurTw7p.fbte
wTTw+KlpSNRMLXlgtEO8b.iomE6GPIoMGo+7giT.sGT5xQNR6t5XzSwnBUoU
cnDFw5MNUw271K62l9Pyd5+Q1S92gPu9uRuzOO9Tk78qsrVq53JO5kWiee8o
Wh1WO+w1bHN9v6tuVzdaJHkAX0ccGtyOWu6ire9eKgcnLW0giEWp5UhdOw.8
6qO+V8G3tvmia5w819CabSY9OIWoNgoQljDnxMplQgZBfKwYEfKPdonRoenw
Q987GuizTBC9G8jI31TF05MNBt3Ojgb2Ag5fxG1th+XeHC21QE3tNm9qvoH7
abqUe0WkCRfylEmj.lfkkKZ4KWhV1.J9.9jGsriqeKwcQjaeIsMem5rnlZNK
xEDJ.x4DK6XeXQlnexDxIWl3erpZMP0xZrM1mL7qwimLwzGdjtclMeWnj0YV
Vh0hGqCQlP3MG7XMeMlvdrJXiiLQ0VhVUJ4u2EYz16WfSAf6VT4Q5QpnsNVv
nq3.ZhdLfNrn3nmKkhIWwAhcnYWh8zzbGZhoOWJP5QBPHM9kxIEB4PhPQvPn
IjFMMsdIEDLLcK5UFjdE4bX211kXxpWQMW1sMPHIqdkoOe6iWsY0ltZ6lZCz
G4g9dMxpRJSUy.T4birl9Se0I4gjdZa3SZpUXRRCAXKiVEgqavxTB2Cxh9kX
4UiZjNhvMeDGeXeWwZFR0UqK0bu5ySvV39pRvtZDXk1jxRyfQHQHgTYbPhwJ
BQtr7VVMxRU9q8kbgBwm9Mkkp+hsB61HXP+KgMfsk8iwLpAJ+QxFeyDV6nxD
84tNj.nQxLc48gVNNosP4QhbykxM3MITQ2M1eStd1H6RkJx4iLdBkZbHT0ma
4KC4JUhq.x1RCKwYSKGZMP7.aTNq2Cuv0nRZl5MvFTR532L11nitT2qoMljj
OZWYRYUJIOmR5tGlL79WhyR6ubY6ZxKoaW8rj69plmbYU6trpYFyUMqrls7U
VV0F7pVvDHqsrpciqZAd2wUsxMdnK8ImSIO1vUZyJcvJeuU9LDqqv.0MPVui
4zvjGu7+iXw0YS0oaREyMoRM.RU09JzEZkrMZi8boglJDWTeHHgDgyFvnHwX
taL1a.Xb4VDj6Ud.sfdtd.zc6R63qEn20cFnA1Uf5FuE2O7tSUYBv.jH2NzU
r7aNbZa3o5ci0Ku7vT60xuiKMZuh8lcK9M5Z9j2OMeumr6fny6h119JsGqTi
gN.Z.VlNUtU13x1njWB04zBeQ5+kQcEJdfLqI8ZLbQ0Vyac4DFS3yyjS7Czd
9Fn29F3wuxXF76oxuQkQJXY+JFtuTwR+qjOQ3KpdmGNEkncqXOm4Kwo8W9pB
rAFOQvOb9WNgDYwcJB3LaqHNAGxPAOGbAE2oH+N4EpFtntvOkfnqdmmurR3c
4iR3oRV4yeVos.+TKVW+ywKn0RkWPF3wSPKNO8uDJsQKPvtV73LE+hWn6xDz
MihoRQHVM7NQFa6530Mw7qZf4u9Or+Ewtz09L7HaE+GkvMVd92zSwlcIZyy4
X1Wgwnhtix3kyQwicjiaxUc1kOCkaAT0kMJjip+GU3ue945fq8E4PL2ncuXv
te9fcb0e7mQITNAB0SvDSSovQGuzbhuSddIcPfZXa7hxHS3o5AX54ncgeFd5
rUKTde556kaU+YnZFBq87fdcY4lkdB2wtCO8F30Q43A0mmwgig6u78KysT0v
H7Mi1e7T3YGpO6NnVNiS0OvGtsWNEs8v9Tfnxcl9w4+b+WW8YM3are8QG2b7
gC61r9zmQmi1rKrx5PBm758QuuNNLNBfGtWw8E89wSQPmTq3yB2uN4Y754mN
cX2tJOJ3Je53JaC+L5ov+LZa7qfmEdk94apCrgqE0Abhczi5LPikOvukdTGl
NTYKcfWuQnc7gBWyG.P2LxxmCHqcpTbyHqXZQ11ZWv35+hJPomZnyBnGVisu
glGbKMEWYcD9hUkpzvFstzsEFYZqotLx51JCJKMNdVns1fvhCFqNcZ4Ao0mV
r.gyJTGVh5vZTmVjZxpT6VlZ25T6VnbakpFe3Ux4Wc8NZrpMJbCdRqao4p1s
20tkK8pcwFLy4xk3ZW0oRwJJFqpb7VIdWYYnCpWPWTulLPzlEw1MTLIzErLU
Pb8FYdJwWDdJf3c2XojeMXo7Cl.VJ0WDVJf3c2XozeMXo.loQlkx+KBKEP1t
arTlGCKUUuFupYreM0xUlX4fl0cCCukjxx3765LwrZO4r5EevPwLUOvL8rBy
D8.yjyJLi0CLi+.wrRWLOsAwj5f02CNxcU10lNaMUBQuG3F26au2372tlpcO
lCqWcHkMejzPq7UVZVoIXXlSgUChyfOvxgenk21AWdSmR4scRk21oU1vIVh6
TKusStr83bN3SvroSwrMOwceXl2xAZ93iwZlRbThiv7CqOSMzGPHUEMLebl9
QI8emkFrNbjRavSETaRR6O4SHvWVGiicjar4n9jMZ.afFZl9orXzwvDOm5la
Dx0MFbBRJC0njADZ9sZEbk5kw25.N6XuIe7shwLmxZmSPW6bLFILzo51PmkX
5onokN1zOLbQvRxggUpvlWCzjkTLSXIyIlPhdSPVR4bv6KKULuJ.Hm6WLEU7
+ho5jiTCClYnawSOGvX5Yw9ATRZyQ5Oe3HEP6AktbjiztqNF8TLpPUZUGJgQ
rdiSU7Mu8x9soOzrm9ej8j+cHzq+qzK8yiOUIe+ZKq0pNtxid4032We5kn80
yerMGhiO7t6qEs2lBRY.VcW2g67y069H6m+2RXGJyUc3Xwkpdkn2SLP+95yu
U+AtK743ldbus+vF2Tl+SxUpSXZjIIApbipYTnl.3RbVA3BjWJpT5GZbjeO+
w6HMkvf+QOYBtMkQsdiifK9CYH2cPnNnr0vg+XeHC21QE3tNm9qvoH7abqUe
0WkCRfylEmj.lfkkKZ4KWhV1.J9.9jGsriqeKwcQjaeIsMem5rnlZNKxEDJ.
x4DK6XeXQlnexDxIWl3erpZMP0xZrM1mL7qwimLwzGdjtclMeWnj0YVM0blM
Ob6ZvvaFESalWNyt3w5byiU+uLdrlK+HWrNODqylYhGqVCKz0iURkxCVh0hG
qCQlP3MG7XMeMlvdrJXiiLQ0VhVUJ4u2EYz16WfSAf6VT4Q5QpnsNVvnq3vC
ZIA.cXQwQOWJESthCD6PytD6oo4NzDSetTfziDfPZ7KkSJDxgDghfgPaQuxf
zqnmA5UxWhIqdE+YhdEKgjr5ULSuSc+6tHg9dSrScAiiScsQjdc8GUtPZRq9
zgOfJbl2NATJtl.xGSBnziPdEKg9Z3h0qAY8RxlAVuxWhop0KIelX8xRHMZZ
Z8RJHXX5VzqLH8Jx4vtssKwjUuhZtraafPRV8JSe91GuZypMc01M0FnOxCCZ
HjUkTlplAnx4FYM8m9pSxCI8z1vmzTqvjjFBvVFsJBW2fkoDtGjE8Kw5enLk
AijQGL9Oj2zj8BV7en+9Onl9i4KMuYvsFKf1smhMzNk7noxQ0x18DSjDhU+7
hDROkPl9zY9b3tNcMjAUptc33H38yolQTxf.kac7gWRm8R35O8V6J9TyqF0H
cDga9HN9v9th0LiUxkZtW84IXKbeUIXWMBrRaRYoYvHjHjPpLNHwXEgHWVdK
qFYoJ+09RtPg3S+lxR0ewVgcaDLn+kvFv1x9wXF0.k+HYiuYBqcTYhhtxgjF
rOMgioXuEJy3PUwYCvR53hVlQIcmdYnv6fIWL8ehUDkA9g2msnNZlE0dDJ11
4aoeI11CwjsdNblY4KwTM11ZxblYHhuskXBY8gd5nkML3izhoOqO1r9bWGR.
zHYlt79PKGmzVn7HQt4R4F7lDpn6F6uIWOajcoRE47QFOgRMNDp5ysAmDJa7
C7ted5zPmJQ21FRFgA1FFpAy3OVTC+Y.0PGLVTCyLfZ.FoFCpQv8gZbYPid0
f53BAx0HQnDY5pQgPP8waPKCkCVkumyQfPyi+fVWV6KTaPB0WM1QlTn1GITq
IETqwxhHoEXa5AXSGNaseO.aNc.acO.aAc.aAVQRNsXt4XgaFsfaFV1j.ZA2
dHgaEwfajfMyiTfspOdkL.vl4CGvkedaAWYeyTiOJy7bcf4eOVHDZ5rRvT2C
LhmrIiGMFg0OGEsbFNCbXXf6gtRXLozdg.RDOtWw6djXDJiaDak.qUBEs7v2
A33FtEzBrEXY7okOmJr9bpnkOmJr9bpHlSPX84jVrIRrVXGnmxLclhblISst
lW7lGI9fQbU6MOWGThaZgPXifJSV7toFiX2CDx.AK+QhOl9nPkNgnRh1yMZE
HSIZ+yn0tvjnislhVvsBKbSK+Jkn8qjVN5HwFLSIw7X.qikRhQuw5XIOfV5u
wF6XZsuIIV+vDjiZywB1bRA1BrfsX1waK02jOh1lQpgm+lIl4ICcF.OeZKnk
kl4S7bbR5oGAbBibrbn6KwW8SiPH3lBbhaFAbRfEmFv5D+xpRZIlLFrcnb.x
baRQ1PkW7lIliSLvjboBGGfSAxQ.mvnYPLznmWVy.jEcL8HfSBr3zMHEAni7
Qy1Ivt+dAsNO.A18IKn096EX2mLmV6SVfcexBZsOYAZyDzZiDBr6SlSqcRHv
teSAshDsvqO6SlNvMGa7l4zROHGqcGNsr6vwZ2gQq3ovQmkUzJtxbr1c3zxt
CW1G82DBtQa2gV5u4XiOKmVwmky5i9DBA2XsWxnkcGloOYKHczeyPa2gVmaB
S2mbYjPzar1cXzxtCCqcGFsr6vPa2gX72Xs6vnkcGF5yEjV9CxPWjC2Qv19g
Iv+2.nZ8mga+UxuR3Sw+Zcb7onMeDCE6XI3OAvdd8G6h+UyE.eK0F+2eY2gM
q2kQeBOU7cJtb4Gdd8yy7JJf9rm7yqepxn176M8kK+vJtoucgJj8Jr7kgbkJ
wU.Yaogk3ruAXadWA1nbVuGdgqQkzL0afMnjzwuYrsQGcotWSaLIIeztxjxp
TRdNkzcOLY38uDmk1e4x1MHuHlc0yRt6qZdrkUs6xpVvXtpIpT9JKqZCcUi4
4MABaKKa27xF6NtrUt0CcoS4bJ4wFtR6sRyVo4qJZdOssvBiT2.Y8dlSCyd7
x+OhUWmsUGDzJtaZkZ.zppsVnKDqVIN9.iNzWg3h5yAIjXb1LFEKJKbixdC.
kK2lfb14aBftYGz20CfNbWZWes.+tt6.MvNCDBDWd+P7NUmwEEGnsy14Wxy+
z1vS0aIqWd4go5qkeGWZ0dE6M6VBb709oteZ+dOYOBQm2Ess0kZVfoT6gN.Z
CVlNUvU1By1njWB04DCeQ5+kQdEJdfLqU8ZLbQ0FzacIEFS3yyjT7Czd9FnC
+F3wuxhF76oxuQkQJXY+JFtuTwR+qjOQ3KpdmGNEknfqXmm4qwocY9phrAFO
QvOb9WNgDYwcJB3LaCINAGxPAOGrAE2oH+N4EJGtnvvOkfnqdmmurR3c4iRX
pRV4yeVoMBeOoqeNdAsVp7Bx.OdBZw4o+kPoMZAB90hGmo3W7BcWlftYTLUJ
Bwpg2IBYaWGutQtecCb+0+k8uH3kt3mgHYK4+nDxwxSCmdJ2rKQgdNKy9JbF
UzdTFwbNjEglAkc.Z62siCk6DT0ENJDjp+GUXve945fq8E4fr336d0fc+7D6
3p+3OiRHcbDJnfImlRgiPdoIEem7+R5hB0v94EkwlvS0izzyQ6B+L7zYqhn7
F102K2y9yv0LLV64AM8xxcM8D9icGd5Mv0ixAFpOOiCGC2e46WleopwQ3aFs
+3ovyNzf1czsbFvpefOtaubJZ6g8o.Qk6L8iy+49utZ3Zv2X+5iNt43CG1sY
8oOiNGsYWXk0gDV406idecbXbD.Obuh6K58imhfVpVwmEtecxy30yOc5vtcU
dTvU9zwU1F9YzSg+Yz13WAuK7J8y2TqXCWupC3D6nY0YfNLefeKMqNLspxVZ
EudiPe4CEtlOIftYjkOGPV63o3lQVwzhrs02fw0HFUfRO0PGJPOrNbeCcQ3V
5Ntx5H7EqJUogMZcoaKLxzdTcYj0sUFTVZb7rPasAgEGLVc5zxCRqOsXABmU
nNrD0g0nNsH0jUo1sL0t0o1sP41JUM9vqjyu55czgUaT3F7kV2RWVsa+qcKW
5U6hMXlykOw0tpSkhUTLVU43sR7txxPGTuftndMYfnMKhsanXRnKXYpf8XLx
7ThuH7T.w6twRI+ZvR4GLArTpuHrT.w6twRo+ZvRALSiLKk+WDVJfrc2XoLO
FVppdMdUWY+ZpkqTxxAMq6NGdKYmkw420YFZ0dVZ0K9fghYpdfY5YElI5AlI
mUXFqGXF+AhYktXd9ChIGBquGbj6prqMc1ZNEhdOvMt22duw4ucMU6dLPVu5
bJaLeCjPO8UVZnoIXXFXgUChyfOyxgetk21YWdSGT4scXk21AV1vgVh6fKus
Cur83bN3CwroCxrMOwcebl2xQZ93iwZlRbThivfDqOiOzGPHUEMLnbl9YJ8e
mkFrNbjRavSETajR6O4iJvWVGiicjCGrEOXxlQfMPCMS+3VL5XXhmScyMBI7
FCNAIkgZTx.BMHWsBtR8xbbc.mcr2jOGWwXlSYsyInqcNFiDF5TcanyRL8Tz
zRGa5mJtHXI4vTKUXyqAZxRJlIrj4DSONQYIkyAuurTw7ZAfbtewTTw+KlpS
NRMTzIPaimdNfwzyh8Cnjzlize9vQJf9DJc4HGocWcL5oXTgpzpNTByZ8FGu
3ad6k8aSenYO8+H6I+6PnW+WoW5mGepR990VVqUctkG8xqwuu9zKQ6qm+XaN
DGe3c2WKZuMEjx.r5ttC24mq28Q1O+ukvNTlq5vwhKU8JQumXf980meq9CbW
3ywM83da+gMtoL+mjqTmvzHSRBT4FUynPMAvk3rBvEHuTTozOz3H+d9i2QZJ
gA+idxDbaJiZ8FGAW7GxPt6fPoPAU3nverOjga6nBbWpS+U3TD9Mt0pu5qxA
IvYyhSR.SvxxEs7kKQKa.Ee.exiV1w0uk3tHxsuj1uuScVTSMmE4BBE.4bhk
c9OrHSzOYB4jKS7OVUsFnZYM1F6SF903wSlX5COR2NyluKTx5LqlZNylGtcM
X3MihoMyKmYW7Xct4wp+WFOVykejKVmGh0YyLwiUqgE55wJoR4AKwZwi0gHS
H7lCdrluFSXOVErwQlnZiQqJk726hLZ69KRaSjyIY7Q5QpnsNVvnq3vCZIA.
cXQwQOWJESthCD6PytD6oo4NzDSetTfziDfPZ7KkSJDxgDghfgPaQuxfzqnm
A5UxWhIqdE+YhdEKgjr5ULSuSc+6tHg9dSrScAiiScsQjdc8GUtPZRq9zgOf
Jbl2NATJtl.xGSBnziPdEKgFa3h0qAY8RxlAVuxWhop0KIelX8xRHMZZZ8RJ
HXX5VzqLH8Jx4vtssKwjUuhZtraafPRV8JSe91GuZypMc01M01VIOL7.PVUR
YpZFfJmaj0ze5qNIOjzSaCeRSsBSRZH.aYzpHbcCVlR3dXVzuDq+gxTFLRFc
v3+PdSS1KXw+g96+fZ5Oluz7lA2Zr.Z2dJ1P6TxilJGUKa2SLQRHV8yKRH8T
BY5Sm4yg65z0PFTo514iif2OmZFQICBTt0wGdIc9Kgq+zasq3SMuZTizQDt4
i33C66JVyPptlOUH8pOWAag6qJA6pwfUZSJKMCFgDgDRkwAIFqHD4xxaY0HK
U4u1WxEJDe52TVp9K1JraifA8uD1.1V1OFynFn7GIa7MSXsiLSTzUNjzf8oI
bLE6sPYFGpJNa.VRGWzxLJo6zKCEdGL4ho+SrhnLvO79rE0Qyrn1iPw1NeK8
Kw1dHlr0ygyLKeIlpw1VSlyLCQ7ssDSHqOzSGsrgAejVL8Y8wl0m65PBfFIy
zk2GZ43j1BkmKxMWJ2f2jPEc2X+M45AjrKUpHGRx3ITpwgPUetM3jPYief28
ySmF5TI511PxHLv1vPMXF+whZ3OCnF5fwhZXlATCvH0XPMBtOTiKCZzqFTGW
HPtFIBkHSWMJDBpOdCZYnbvp78bNBDZd7Gz5xZegZCRn9pwNxjB09HgZMofZ
MVVDIs.aSO.a5vYq86AXyoCXq6AXKnCXKvJRxoEyMGKbynEbyvxlDPK31CIb
qHFbiDrYdjBrU8wqjA.1Le3.t7yaK3J6alZ7QYlmqCL+6wBgPSmUBl5dfQ7j
MY7nwHr94nnkyvYfCCCbOzUBiIk1KDPh3w8Jd2iDiPYbiXqDXsRnnkG9N.G2
vsfVfs.KiOs74Tg0mSEs74Tg0mSEwbBBqOmzhMQh0B6.8TloyTjyLYp007h2
7HwGLhqZu445fRbSKDBaDTYxh2M0XD6dfPFHX4OR7wzGEpzIDURzdtQq.YJQ
6eFs1ElDcr0TzBtUXgaZ4WoDsekzxQGI1fYJIlGCXcrTRL5MVGK4AzR+M1XG
Sq8MIw5GlfbTaNVvlSJvVfErEyNdao9l7Qz1LRM772LwLOYny.34SaAsrzLe
hmiSRO8HfSXjikCceI9peZDBA2TfSbyHfSBr3z.Vm3WVURKwjwfsCkCPlaSJ
xFp7h2LwbbhAljKU33.bJPNB3DFMChgF87xZFfrnioGAbRfEmtAoH.cjOZ1N
A182Kn04AHvtOYAs1eu.69j4zZexBr6SVPq8IKPalfVajPfcexbZsSBA18aJ
nUjnEd8YexzAt4Xi2LmV5A4Xs6vokcGNV6NLZEOEN5rrhVwUli0tCmV1c3x9
n+lPvMZ6NzR+MGa7Y4zJ9rbVezmPH3Fq8RFsr6vL8IaAoi9aFZ6Nz5bSX59j
KiDhdi0tCiV1cXXs6vnkcGFZ6NDi+FqcGFsr6vPetfzxePF5hb3NB11OLA9+
F.Uq+Lb6uR9UBeJ9WqiiOEs4++16poGGG2H584WgwfbJX1Er325xdHYAxgff
Df4XVf.2c6oGiwscC2dl4T9uGIQJYIYJwRx1kn63EXaL1xV9wpJVUwhTu56G
bOriMveNv9xxuu4v+o+G.9Ad13+3ya18vxMkxmU6q+L0Wt4Mu54mGX0O.8k2
4ur7wVsZyO12Gt4Mq9K8giRgx+5TekCtFOhqtA6.DVRvm.bgq+dl4qxYWN7B
GQkzuzahDTRQ627fmniN9buVPLI4u0llhx1RRdkjLLGlLc9KI3i1eyGaWfU8
b6FhzRtzpMHydWscQTa.iP0V0rM+Cvxc01zUavLLa6tZ6rUa7KnZqI4Ccjqb
1meaWsPwWnDKTxE0T.4PJVWS0MS1k0b5o6i27+QncCRrNHjUhvxJ0DjUsIWn
iBK9PNqLNtDxwrPbQ2NgDxQbYWFE6PVFdHylvPtIQAEV26HuKGyq6LDfBdes
d7cJ+.MQtABw.Wc4F3wcmIjUaocPB8K+9u+oU66RJqG+yUy02.+Ng7p8Ure4
vy.o26m9x486k7UIr9sMqeZPUcVS9gNywCV1n92ZFf4o04+YktRVXDE+WozU
n3YxRt50Z4h1Lza2IJ4NyL7xIJlLMyXcT7aFieR.M2ump5KprRAT9qX4FoBJ
9W4uivHZ+M2sect+s5kdVohKnY91yXyrLQ1mB9uBhDY82TjwAOiDmOFJGBr.
VA0eSQ02jW6a3n+BSg.Q29a91QMA63akaSkq3qtWELgOSF5miWKqkJVVI734
CKNu3eITZqVfvbs91Yq+EOJ2k4C2RIlpX.AcF24ywdZ4gk8Z7a5w3u6ur437
tBke4.oTk+oFCNn5b3LxoMax8mWYxrskkQKmGMGXCwZw1JemwxanIUP0cxQ8
Dot+iVF3e4Kcgq+OxIEvwFVa.WtDwdcwm+45bQGD2+jqyooU3jiGIo3KT1Wx
PBndVNun4fY09tUZ5Kq2r5Gq1+l2OTEgc8wlb1e4jX2HlwbjdYSVSO27XytG
+lKwilEFZL2icutZ6wOeSyk1gFcex0aec+p2B3.Md0sBVvpOgutaOue8S61V
.hVeyh2t5m6eGhv0behsKeMvW9vtcadX49er9s0OrYUK8Ptk7xsqeY4gUGV6
vCmU+8V+xq6W6nTs52a01k42iu91i62sYSqak6J+HvUdZ0OV+3pet9oCe0ka
AqwOeeTwFNtpyYIFgr5rNFlOyL.Y0ggpJGfJdYDvKenFqUcBnydvxuEFr91S
wYOXEy6f8zjW6aD6WphV1fKsE.FdruMyKN4LYmd1rmWFsmU5qmWJrmWZr8jJ
KtzYOuTZG17exo11W5scmTMTW4LDNFWhtWnodCPY2ka9GpoiN9kdLcUhq.ec
K5omJL+sZn+DTjUANQoK6MoH05zPyeCj447jzPIC4t7c3YoVqQ0L+rv+5WWs
fgvZzUETvkXgxlZRRaJ06p8UOUeu8dL9DOyl8t6AlnbJeXNQ5FlCXIQbNU73
bdgISklA5.X18Rivjj65kEhp9daRZRxuQLIqDlLdhZRJtER9xKEq1e3jK6KP
lJoeApnVjZ2ds6HSrzK+KPcSrb.kLssH02NVjBG6QjtVjDs3pWW+3ATUpz6N
T56go80zod3aOu8ohaZ4c+yk24e2sMI+khK8qu9Xqp.OzNf0taVs94ud3kk6
ed81tcyrG1c3vtWBes0a8aSRIv5l4t6a9ika9d4O+ujaNzzpZ2q0Wp8UV+Rd
.5WV9125dC2r5KG5618ss6dHrj4umektBldMRxQU3gZoDpO.2vxxhqNdECkF
+PoRuIrJThq4Lmd8lPfnddJ98XnJcP24iwHqZ82ztGCm2NED97u7+Cahvuv8
Q8UuW1GAN6lXiDvTqrpoVF48hkMgsjd96Et913JtXNfqaiqzoVxhbdBU+3Jg
kmU.uOmXbyIDy9bh+7h1mLlAzw9ZeBIXOSmO+kGIdxrUqBMUSlkqRsjYqJ2t
1E3sThos2VIydOi0asLV0uaxXsZ9i7dz4oDc1bijwpOvR5lwZRchG7Bq6YrN
o4DY2BYrVoiS3LVELZlSz9gkssj72iIF8ORPtcAfGdpx0LiTwPGZexcbvbGT
cmb3tiiQpJ4ytiCDqPyqhY5zbEZh4+rTfLiDmfzZZblTRnDRDxDrDZ28qLI+
Jpa.+JUp3j0uh9FwuhWPlr9ULyeRc+sXhPCalSpyRSRcCIj95xu25BEGZ0G2
8c2SGHeXAnTbp.jSp.LKgxJV5db2uG8ZRQujrafnWUp3TM5kDtQhd4EjVcZF
8RxSvxzc2uxj7qHtEVssWEmr9Uj2Jq11IHSV+JTsuxC7nzDSDVQBRZWtc5T6
onQpSHeyUzTBK6tu4I3aNA1VwUK+FNcrvTpiUvnzw8cr9upyPFXYkhYZFh2c
x8YHibFx7uIiusZSzvt.qIgTJ33TxkZ2OQYrCEQKx7gue3vtswJ+j6zuIDlJ
hmtM8SOfPqs.6D1Rsf1hJNTStyFk6zMMEqOEL+Ew6gkuEKmO2yE37UFOEmlp
P0j5i6+j46H2.2Azu2GWsS4.4P9OQxCx3ETBhJW2.w6i4IyEeWwBybkXi0e0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.UO+7Z4gcOWz7yv0dH7axrI01QdEQm0WT6phWX42uQop5u
icWUPYAYmetVX0lEvBrmoCvs4.vD7y8IJOuQpLh1A69Er9FvJJ4J283FOF56
cNb3oYzHUw4TyK53hA54MwevTQMtm+SE6ugcJJ3pdwXhaRWuiHkNUrU4Yb+T
wNkchUeKbpXqTwo5ohUmLmJVDmLVuvz87homOYYOafslnSFa2xkF7LT3OMSr
KWjod3jV8PmkUBZXaXjFf0PkzvbCHMzYTIMr2.RCmSEJjFYWFowwFM5I0G+n
.JTkHaHlNoBjYcqpH15pFtxi8W0wAUqiE0VjntnZ+PxfZCRTqSJYsFqIhJsr
Qz1wf6zwJQaFCt4oCt0iA2hzA2JrSKSL6aIVbKRKbKvZmjX9A4Xk2PZgaXDA
Km.rAi6g.vT0M0T9WL2imhZFdKpG.8kPQHzoil.jWhQDOOi8q8Hhg02TVZYa
gE1IEpUnyrLAwMfA2SLRPwFApJ1ae2FQyY0u5ZMhPmqrIszDXyUNsRARgc9p
ch1O5RKFvVZ+n40u3ZNdvLgHPNT2D5AE6rTDBeUl.Y8ql6QDbIFPVWAEuliG
EVWs1zxxB6hJko0hbTnWToJ8vMfE2PZgaNVbySKbKvhawsm8sTcVNH87RukW
8h419QNQ69h1Q.Tb7.3UCJISSwfByjYIepqqT8q177o415AE2RwfRfcPMAME
+ndo3XCRhkGpTuMm2LIeI.pewbazIl3lJ0xnyMnxjTLnv3dPL0Jzzz8fay1A
MECJA1A0YLSxMdjWcKOFV2coUQmvlhaZgZI5c7NsVQgDaIZjoUIZjXKQSZUZ
.odLlIoyBJjnW3YZsalRzIlmVkxShc2LEo0tQIwtalxzZ2LkX2yIYhIuwtyR
7zxeh.cE1SqBYIv5+VjVExRf0+MOs7eKPubvzx+s.s+6zJ+DAV+2bdZ4OAse
vzZYC7rw3+NgvM1kMvSK+fbzKaHsh6vQuAboUbdN13NPZs7RN13N7zJtCWLF
+2IDtwF2ARL+2XW2.OsV2.mMF+IoCtArwKgzJtCXFyozLc7eCni6jVqmGTi4
LjlPxarwcfzJtCfMtCjVwc.zq2IwruQeFoSq3N.50ocIyGz+lUbPVL9GyO.P
v6XC7.fGguwhw0XA4Yr93XrA3WLmTn7uN8W4fqwC7pavN.cSDj8GcbYk+jDK
jcaTC3nYh9kdSjdI93iK2dvSSMGeJXKnUh72ZSSQYaIIuRRFlAJlN6SDjzDZ
QD17JVJHDkSbwUaNpkQ3ayF2UaSWsATp17D30c01Yq13Tp17D9m+3LeWsMc0
l3Bp1ZRcLGoMl8421UKrrEVXgkuvJh6Fkqcj+urKywDleyZ8+HztAYOFDxJY
XYkZBxplsWmfBBv+Dz4DAhi7WV836z1pyDaoNHF4pvib10XxMHb8VoLy8I2m
4jaMg9jyT20ZWFslgPsV0jM+if7c01zUaV5mrcWqc1ZsLhx+QJWHUKj5E08g
1AzqpRJyKCRpzeDrKW5Osoo5ixJqdQijMBlfniMAcsxGEqKKfM.sBddRDdHI
ROKUEtbFOute0qq19zh2poGsgjJtC.ulivt4JZmvu9RkkO9sASd1s7AmMhgL
oQPaDwUWZ71OW9Zbogy1.izH.cQeEjKRBCWZb02QYCSeuyU3xvhNxiAJTTV5
Fs7tpneUAkqXy6X3tpHrpvb0yL7wCaVucwe7wO+4+5+7er3esa+gEve7w3ZL
eW4foFku7KpK8fRrdVAjXBRr1co6ihLXn0x5Y4eWK5lW2SXF4HFriXHmc4JL
VrRBl4FPtRe6xsAJ5RKyQAAkr3i6x6Valu0IF5ty1dgwoLcaqSjTeOqhs1M6
F6jcErCtK1mnZPiIKVLwoCSs+45ASZZkSFLxIE8XBhgIIsXBvHmXzioXxIaF
8XJlMt0ROlDwvDw9mXHrmrsNIjWcLYyvhIAcXxhESzo6rFrXhtXKc945ASz5
GuiZoGLIoGSQ8YJnESX7EXxnGSwjSFK8XJlMtwPOlhEawPr+ILopPNhhp3HE
QFLw5LJRi+ZrXwDcweMFrXhPcmFKlnK9ametdvDsw55nV5ASB5wTz3JbRwjF
iu.skdLESNoMzioX13ZM8XJV7WMs9mzX7iqkjFaQavhI5hsn0XwDg5NEVLQW
rkN+bX5EMzfonxIN8XJpOSfTLov3KPYnGSwjSJM8XJlMtRQOlhEaQQq+IEF+
3JAowVTZrXhtXKJEVLQntShESzEaoyOWOXhV+3cTKX5.Lzfon9Loc+ePkpB4
HJlwDs9KkX7WJ0zioX1RRE8XJppaFzcwh+Jo0GtDSrt1DM+0GSJrXht3uRIV
LQntSfESzE+syOGFlhkFLEUNwnGSw7YJncWMDX7EHTzionxII8XJlMtPPOlh
EaQPq+IAF+3BfzXKBIVLQWrEg.KlHT2wwhI5hsHvbVrDz5GWf4bzwynGSw7Y
xoc+e3X7EvkzionxIA8XJlMNmSOlhEagSq+INF+3bFowV3BrXhtXKbNVLQnt
CvhI5hsvwbVr.Z8iywbN5.K8XJlOSf18+AUpJjinnFSjhH.yZ6f9h+xtNXBi
ObPQKlDX1fSPXlATEcZmPOCnJpctfZMnAkFjXacTEWAD8cJZtVnB0Tvdqkw0
DU.JTQorBS5cYv3DUELngJeRjrjQAkfn9Uj.WK6bfqBzzBWc1jfK3ooDlr9U
j.Wk8bfKmYnEtRy4.WAvnEtiMZWa35mpQGb4pyAt9oZzAWXhRWYIbM5iuhF3
1assifWGUloEp5WQDdOKOudWYz44E3xyAuZAmX7BhyAudeuDhWF+bvq246kA
ubT1u.w4DhpXHDWocGphloJw0Z2gpnqKialATIhhJMwnBacQnqNxcsh6yCWF
wnxhFUBBQkAMpHzphqQiJNgnRhxuffXYEpU6S7ddAn1fIf3c8xgp39PYDiJT
KFlXLgZiuHFS.JuBDCJTL2BsXBv7jYBvbfp3pOyLfpntOAhSqBWdU.eFPUbY
ELCnJt0NaFPUzPMLhSrBPs3Tlk1TiA.MpHL0XfgFUTpAQkWE8XJ5DPhm+wxP
q8HbIDLTa4Ki3XfLTKMkomATEMZCi3DiYXNbJYYy.nhErIyNCfJtUELCnJtU
E0dq.r7SKggkYLrfZpQkyew+8C+OvYUJh5
-----------end_max5_patcher-----------
Keith
Head Honcho
Re: BIGFOOT MODE
Postby Keith » Thu Mar 17, 2011 11:24 am
The BIG problem here is user interface. The UI is designed to treat each key as an entity. We would need a vastly different UI for any mode that would so totally cross over multiple keys and we, as of now, do not see a lot of demand for something that would take so much work. Obviously if that changes we would consider looking at this feature request.
- Keith
kasper_toeplitz
Re: BIGFOOT MODE
Postby kasper_toeplitz » Thu Mar 17, 2011 1:12 pm
but, keith, if i remember correctly the UI (as said, i don't use it, since it does not fit my personal needs) you can set, for a given key a"reaction" to what is done with another key (a modulation line which reacts to what is done with/to another key). Adding a mod line like "inc CC #xxx", should be possible......
or routing 2 keyx to the same CC, but one with inversed (127-0) values?
best
kasper
