Software crashing
Get help from other StringPort users.
madfiddler
Software crashing
Postby madfiddler » Sun Dec 09, 2012 11:00 am
Just upgraded to 1703 release, and installed the 1.34 drivers.
The Mainframe loads up OK, but the processing apps fail on load. Here's an example, all help greatfully received..
Process: SP-Processing 1703 [1012]
Path: /Applications/Audio/*/SP-Processing 1703.app/Contents/MacOS/SP-Processing 1703
Identifier: com.cycling74.com.Max.SP-Processing1703.appRuntime
Version: 5.1.8 [45300] (5.1.8)
Code Type: X86 (Native)
Parent Process: launchd [144]
User ID: 501
Date/Time: 2012-12-09 18:57:17.857 +0000
OS Version: Mac OS X 10.8.2 (12C60)
Report Version: 10
Interval Since Last Report: 189072 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 66 sec
Per-App Crashes Since Last Report: 2
Anonymous UUID: 7CBF25C8-4357-AD2A-997D-8D91E8AC99B2
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000020
VM Regions Near 0x20:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Audio/*/SP-Processing 1703.app/Contents/MacOS/SP-Processing 1703
__TEXT 0000000000001000-000000000037e000 [ 3572K] r-x/rwx SM=COW /Applications/Audio/*/SP-Processing 1703.app/Contents/MacOS/SP-Processing 1703
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.cycling74.umenu 0x0ad81ed5 appendatom + 66
1 com.cycling74.umenu 0x0ad820ff jumenu_atoms_to_text + 218
2 com.cycling74.umenu 0x0ad85154 jumenu_add + 232
3 com.cycling74.umenu 0x0ad85be0 jumenu_append + 46
4 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0001b7ec typedmess_fun + 782
5 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0005e9db outlet_anything + 795
6 com.cycling74.MaxAPI 0x01f7a441 outlet_anything + 60
7 com.cycling74.adstatus 0x0add2df6 adstatus_inputmenu + 218
8 com.cycling74.adstatus 0x0add31f8 adstatus_reset + 382
9 com.cycling74.adstatus 0x0add3cfa adstatus_loadbang + 18
10 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00057c16 linklist_funall + 68
11 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00153263 jpatcher_loadbang + 209
12 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x000b4a3e object_method + 896
13 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0003a73b jpatcher_doloadbang(object*, void*) + 35
14 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0015c0d5 jpatcher_traverse_iterfun + 209
15 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00057c8f linklist_funall_break + 79
16 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0015bcbf jpatcher_subtraverse + 59
17 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0015bdae jpatcher_traverse_flags + 92
18 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0003a790 loadbang_patcher + 52
19 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0000fd6a lowload_postload(object*, bool) + 48
20 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00010c1a lowload_type + 1390
21 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00010ca9 intload_type(char*, short, long, symbol*, short, atom*, short) + 119
22 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00011623 nameload_unique + 331
23 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00044205 pcontrol_doload(pcontrol*, symbol*, short, atom*) + 125
24 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x000315c8 defer_exec(_defer*) + 60
25 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00028b81 sched_dequeue + 119
26 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00011cc7 max_tick + 77
27 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0018bd00 maxapplication_eventtimerproc(__EventLoopTimer*, void*) + 22
28 com.apple.HIToolbox 0x91b7854c TimerVector + 22
29 com.apple.CoreFoundation 0x909d59b6 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
30 com.apple.CoreFoundation 0x909d5355 __CFRunLoopDoTimer + 709
31 com.apple.CoreFoundation 0x909ba162 __CFRunLoopRun + 1730
32 com.apple.CoreFoundation 0x909b963a CFRunLoopRunSpecific + 378
33 com.apple.CoreFoundation 0x909b94ab CFRunLoopRunInMode + 123
34 com.apple.HIToolbox 0x91b6815a RunCurrentEventLoopInMode + 242
35 com.apple.HIToolbox 0x91b67ec9 ReceiveNextEventCommon + 374
36 com.apple.HIToolbox 0x91ccd30c ReceiveNextEvent + 79
37 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00215d36 juce::juce_dispatchNextMessageOnSystemQueue(bool, bool) + 554
38 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0021f9bb juce::MessageManager::dispatchNextMessage(bool, bool*, bool) + 79
39 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0021fa7a juce::MessageManager::runDispatchLoop() + 42
40 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0021e3d5 juce::JUCEApplication::main(juce::String&, juce::JUCEApplication*) + 605
41 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0021e4af juce::JUCEApplication::main(int, char**, juce::JUCEApplication*) + 125
42 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0018c144 main + 76
43 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00005582 _start + 216
44 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x000054a9 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x98d079ae kevent + 10
1 libdispatch.dylib 0x96155c71 _dispatch_mgr_invoke + 993
2 libdispatch.dylib 0x961557a9 _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x98d070ee __workq_kernreturn + 10
1 libsystem_c.dylib 0x98aff04c _pthread_workq_return + 45
2 libsystem_c.dylib 0x98afee19 _pthread_wqthread + 448
3 libsystem_c.dylib 0x98ae6cca start_wqthread + 30
Thread 3:
Thread 4:
Thread 5:
0 libsystem_kernel.dylib 0x98d047d2 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x98d03cb0 mach_msg + 68
2 com.apple.audio.midi.CoreMIDI 0x04fbe22d XServerMachPort::ReceiveMessage(int&, void*, int&) + 101
3 com.apple.audio.midi.CoreMIDI 0x04fdbae0 MIDIProcess::RunMIDIInThread() + 144
4 com.apple.audio.midi.CoreMIDI 0x04fe1c48 MIDIProcess::MIDIInPortThread::Run() + 24
5 com.apple.audio.midi.CoreMIDI 0x04fbf805 XThread::RunHelper(void*) + 17
6 com.apple.audio.midi.CoreMIDI 0x04fbf2ee CAPThread::Entry(CAPThread*) + 196
7 libsystem_c.dylib 0x98afc557 _pthread_start + 344
8 libsystem_c.dylib 0x98ae6cee thread_start + 34
Thread 6:
0 libsystem_kernel.dylib 0x98d068e2 __psynch_cvwait + 10
1 libsystem_c.dylib 0x98b01289 _pthread_cond_wait + 938
2 libsystem_c.dylib 0x98b01512 pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x93ce46ad TSWaitOnConditionTimedRelative + 177
4 com.apple.CoreServices.CarbonCore 0x93ce4184 TSWaitOnSemaphoreCommon + 272
5 com.apple.CoreServices.CarbonCore 0x93ce440d TSWaitOnSemaphoreRelative + 24
6 com.apple.CoreServices.CarbonCore 0x93cca1a3 TimerThread + 324
Thread 7:
3 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0021518c juce::WaitableEvent::wait(int) const + 122
4 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0029220b juce::Thread::wait(int) const + 27
5 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00220a27 juce::InternalTimerThread::run() + 229
6 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0029229e juce::Thread::threadEntryPoint(juce::Thread*) + 142
7 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x00215267 juce::threadEntryProc(void*) + 17
8 libsystem_c.dylib 0x98afc557 _pthread_start + 344
9 libsystem_c.dylib 0x98ae6cee thread_start + 34
Thread 8:
0 libsystem_kernel.dylib 0x98d05eb6 __accept_nocancel + 10
1 libsystem_kernel.dylib 0x98d04e91 accept + 39
2 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x002d6749 juce::StreamingSocket::waitForNextConnection() const + 257
3 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x002086a3 tcpconnection_listenthread(_tcpconnection*) + 27
4 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0006040a systhread_threadproc(void*) + 60
5 libsystem_c.dylib 0x98afc557 _pthread_start + 344
6 libsystem_c.dylib 0x98ae6cee thread_start + 34
Thread 9:
6 com.apple.QuickTimeComponents.component 0x97ebe5ac 0x978c8000 + 6251948
Thread 10:
6 com.apple.CoreServices.CarbonCore 0x93c857ea AIOFileThread(void*) + 892
Thread 11:
2 libsystem_c.dylib 0x98b8eafc pthread_cond_wait + 48
3 com.cycling74.MaxAPI 0x01f853ce systhread_cond_wait + 38
4 com.cycling74.udpsend 0x0b9d80ea udpsend_dequeue_dgram + 42
5 com.cycling74.udpsend 0x0b9d8165 udpsend_send + 30
6 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0006040a systhread_threadproc(void*) + 60
Thread 12:
0 libsystem_kernel.dylib 0x98d06b5a __recvfrom_nocancel + 10
1 libsystem_kernel.dylib 0x98d050ba recvfrom + 60
2 com.cycling74.udpreceive 0x0b9d1a96 udpreceiver_listen + 82
3 com.cycling74.com.Max.SP-Processing1703.appRuntime 0x0006040a systhread_threadproc(void*) + 60
4 libsystem_c.dylib 0x98afc557 _pthread_start + 344
5 libsystem_c.dylib 0x98ae6cee thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000020 ebx: 0x0ad81eab ecx: 0x00000000 edx: 0xbfffd4f8
edi: 0xbfffce50 esi: 0xbfffca10 ebp: 0xbfffce28 esp: 0xbfffc5f0
ss: 0x00000023 efl: 0x00010246 eip: 0x0ad81ed5 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000020
Logical CPU: 0
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 973
thread_create: 2
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=200.3M resident=82.3M(41%) swapped_out_or_unallocated=118.0M(59%)
Writable regions: Total=611.4M written=484.3M(79%) resident=540.4M(88%) swapped_out=0K(0%) unallocated=71.1M(12%)
REGION TYPE VIRTUAL
ATS (font support) 32.0M
ATS (font support) (reserved) 4K reserved VM address space (unallocated)
CG backing stores 1760K
CG shared images 1216K
CoreServices 3092K
MALLOC 542.3M
MALLOC guard page 48K
Memory tag=240 4K
Memory tag=242 12K
Memory tag=249 264K
Memory tag=35 4852K
Stack 70.1M
VM_ALLOCATE 16.1M
__DATA 12.4M
__DATA/__OBJC 188K
__IMAGE 528K
__IMPORT 760K
__LINKEDIT 43.8M
__OBJC 1828K
__OBJC/__DATA 40K
__PAGEZERO 4K
__TEXT 156.5M
__UNICODE 544K
mapped file 84.3M
shared memory 308K
TOTAL 972.6M
TOTAL, minus reserved VM space 972.6M
Model: MacBookPro5,2, BootROM MBP52.008E.B05, 2 processors, Intel Core 2 Duo, 2.8 GHz, 4 GB, SMC 1.42f4
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334548312D4346382020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334548312D4346382020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.98.81.22)
Bluetooth: Version 4.0.9f33 10885, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST9750420AS, 750.16 GB
Serial ATA Device: MATSHITADVD-R UJ-868
USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 2
USB Device: KMI-StringPort, 0x1f38, 0x0001, 0x26400000 / 2
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0237, 0x04600000 / 3
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x04500000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8217, 0x06110000 / 4
madfiddler
Re: Software crashing
Postby madfiddler » Sat Jan 12, 2013 4:07 pm
Looks like a mixture of drivers/software version. Managed to get everything running... sort of.
Return to “StringPort Users' Help Exchange”
