"Long Press" Variable Timing in Standalone
Lid55
Postby Lid55 » Sun Jul 20, 2014 11:17 am
Actually, what it could be renamed as (in the sense that I'm talking about it here) is "Delayed Trigger", whereby the user specifies the exact time where, after holding down the key, the message is sent. This way you could have "short" triggers setup as well.
For example, I could use this to send a message:
- immediately when the key is pressed
- 350 ms after holding the key down
- 1000 ms after holding the key down
I'm getting into advanced looper control, and this kind of functionality could help simplify the looper, as well as make it moe intuitive to use
NoFi
Re: "Long Press" Variable Timing in Standalone
Postby NoFi » Sun Aug 31, 2014 4:58 am
+1 Maybe your idea can solve my problem ?
viewtopic.php?f=13&t=2541
But if what you want is delay, you have a delay modifiers in each the modline tant can delay the message send.
Lid55
Postby Lid55 » Mon Sep 08, 2014 5:31 am
no, unfortunately, the Delay feature only works in HostedMode, not in StandaloneMode
