Pairing of 2 mono channels?
Your source for KMI News and Announcements
mendomusic
Postby mendomusic » Thu Apr 13, 2017 10:57 am
Hello KMI team,
is there a possibility to pair 2 mono channels together?
Use case:
I would connect a CD-player using a RCA/Cinch to TRS adapter cable and the 2 TRS cable to 2 of the K-Mix inputs, say channel 1 and channel 2.
Now, I would like to operate the faders simultaneously meaning that when I increase volume in channel 1 then channel 2 should automatically go up as well.
So the two mono channels would function as a stereo-subgroup.
Looking forward to your reply,
Mendo
Re: Pairing of 2 mono channels?
Postby TheOtherSupport@KMI » Fri Jun 23, 2017 6:48 am
Yep, totally possible! You can pair them from the Editor, or from the K-Mix by holding shift and hitting the rotary above the channels in question.
Return to “Announcements”
