Kemper Looper Control
a place to share your SoftStep Scenes and Presets
smfelton
Postby smfelton » Fri Sep 18, 2015 10:47 am
Hi everyone, I received my Soft Step 2 yesterday, so this is my first post on the forum, although i'm a regular on the Kemper forum.
Here is my first 'preset', it is to control the new looper on the Kemper Profiler. It is still work in process but works well. I've included a picture showing the functionality. The '6' led is red when recording, and green when playing. Press stop (7) three times and it deletes the loop.
Known Issues.
Keeping 6 held does not record, you must press once to start recording, and once to stop.
If you use trigger (9) to start play back you cannot stop with stop. You must press play (6) first, then stop.
Led's better operation- ie trigger lights playback led, see previous issue too.
Haven't implemented reverse and 1/2 speed yet.
Enjoy
Shane
http://www.alien-touch.com
KPA-Looper-v0.1.zip
(56.41 KiB) Downloaded 207 times
smfelton
Re: Kemper Looper Control
Postby smfelton » Sat Sep 19, 2015 10:32 am
Updated version (v0.2), slightly improved performance.
Start and stop on Trigger implemented.
External expression pedal settings for Wah in "Nav pad"
KPA-Looper-v0.2.zip
(58.96 KiB) Downloaded 197 times
smfelton
Postby smfelton » Tue Oct 06, 2015 2:14 am
Updated v0.3
Fixes strange fault where occasionally there was a weird effect when the Wah was in full heel position.
Shane
KPA-Looper v0.3.softsteppreset.zip
(4.69 KiB) Downloaded 172 times
Return to “SoftStep Scene Share forum”
