12 Step iPad 2 + iOS 8
EASonBASS
Postby EASonBASS » Thu Oct 02, 2014 8:40 am
Anyone successfully using the 12 Step on an iPad 2 with iOS 8?
I stupidly upgraded to 8 ignoring my own advice and experienced an issue with the 12 Step not working at all (Apple camera adapter and power to the 12 Step).
Fortunately, I was able to downgrade to 7 and all is right with the world again except for Garageband which was automatically upgraded with 8 is now incompatible with 7.
Re: 12 Step iPad 2 + iOS 8
Postby emmett@KMI » Thu Oct 02, 2014 10:07 am
We have tested 12 Step with iOS8 and it works as normal but I have seen several articles where people with iPhone 4s and iPad 2 are warned against upgrading to iOS8. They report general glitchiness/slowness and app problems.
Glc666
Postby Glc666 » Thu Oct 02, 2014 2:16 pm
I have an ipad 3 retina with 12 step. Yesterday i play normally, today i upgrade to ios 8 and 12 step doesn t work at all. Connected to pc it works normally but to ipad no. What can I do?
Postby TheOtherSupport@KMI » Fri Oct 03, 2014 5:31 am
If you upgrade to a new operating system and your gear isn't working as it did yesterday, that would definitely point to the operating system.
You could try reverting to iOS7 and wait for the next incremental update hoping that there is some sort of fix for your issue.
EASonBASS
Postby EASonBASS » Mon Oct 06, 2014 8:50 am
@glc hurry and try to revert to iOS 7. Apple stops signing previous versions soon after release. Hope it's not too late. Otherwise, you'll need to wait for subsequent dot releases that'll hopefully fix midi issues on some of these devices.
Postby emmett@KMI » Mon Oct 06, 2014 12:08 pm
Glc666 - Are you powering your 12 Step externally?
EASonBASS
Postby EASonBASS » Tue Nov 18, 2014 6:22 am
EASonBASS wrote:Anyone successfully using the 12 Step on an iPad 2 with iOS 8?
Reporting back that with iOS 8.1.1 and the recent updates to Sampletank (Nov. 7 v1.8) and Animoog (Oct 23 v. 2.2.3) are all working as expected on an iPad 2.
Thanks kmisupport for responding to issues while iOS and the apps worked through their updates
Onebass
Postby Onebass » Tue Nov 18, 2014 12:18 pm
Are you using the official Apple camera kit or a copy camera kit?
I've got a iPad 2 and Air and can't get either working with the 12 step I even have the Midi box to power the 12 step. I believe IOS 8 won't let you use camera kit copy's but don't want to buy the official camera kit if it makes no difference.
Thanks
Postby TheOtherSupport@KMI » Tue Nov 18, 2014 12:42 pm
You need to be using the official camera kit. Third party adapters may or may not work.
You don't need the expander to power the 12step, you can just run a USB mini for a usb wall adapter, into the 'Expand' port.
Danny G
Postby Danny G » Fri Dec 26, 2014 2:14 pm
Don't upgrade to 8.1.2, it doesn't work with my 12step/animoog setup anymore. I have a iPad mini 1st gen, authentic camera connection kit, and tested external power for 12 step. Anyone know where to submit this to Apple? (It's even more frustrating now that you can't roll back from 8.1.2!)
