save presets
phill
save presets
Postby phill » Tue Feb 12, 2013 2:02 am
Hello
I am a new owner of a 12 step and am having trouble saving presets, If i save in the unused area preset 60 up, it saves in the editor ok and appears in the preset list but even after pressing update, I cannot select preset 60 or above on the controller.
I can make changes to existing presets save and select them at the controller
Also when I select a preset in the editor and press update should'nt that change the preset on the 12 step also? mine does not.
Thanks for your help
Phill
Re: save presets
Postby TheSupport@KMI » Tue Feb 12, 2013 2:37 pm
I suspect your preset may not be in the "setlist" — mostly because there are 60 presets in the setlist by default.
Is the preset you created in the "setlist"? The 12 Step will only receive presets that are in the setlist. This is so you can store a bunch within the editor, and then select a few that you actually need to go to the board. Just click the "open" button under the word "SETLIST", then put your created scene in whatever slot you want. It will get sent to the board the next time you press "update".
And you should remember that the presets are numbered on the 12 Step according to the setlist number, not the number in the main preset list.
