Hitting Pad 7 turns kick off on logic pro X
Posted: Fri Jan 22, 2016 1:58 pm
by ralph
Just got my quneo. Installed editor. Opened logic. Created drummer track. Great I can play! However, as soon as i hit pad 7 (the hihat) then the kick stops working. Looking at logic, pad 1 is still triggering but the kick isn't working. I've checked al the levels, nothing is turned down. Changed all the CC's on pad 7, same problem. If i reload the preset on logic or chang drummer then the problem is fixed until i hit pad 7 again.
Can anyone help with this? I can't make heads or tails of why it is doing this...
Re: Hitting Pad 7 turns kick off on logic pro X
Posted: Sat Jan 23, 2016 8:21 am
Sounds like some MIDI message coming from pad 7 is muting the kick channel or something similar.
I know you said you changed the CCs, but be sure to save, and update (send) the preset.
Although, the CCs shouldn't have any default behaviors. CCs 41, 42, and 43, don't have any general functions attached to them.
When you say 'the kick isn't working', that's not very helpful for trouble shooting. It's not playing? It's muted? The sample gets deleted? the volume envelope has changed?
Posted: Sat Jan 30, 2016 11:51 am
by blueleaf
TheOtherSupport@KMI wrote:Sounds like some MIDI message coming from pad 7 is muting the kick channel or something similar.
Thanks for the reply :D
I did a firmware update and it seems to be working now :)
However, I'm now having problems with the sliders and rotaries. When assigned to anything in logic they just make the parameter jump around like crazy. I only have location cc's on the strips/rotaries and tried fixed and variable velocities. This also happens with the logic factory preset and file that ships with the quneo (i restored the factory presets from the editor). Any ideas?
Posted: Mon Feb 01, 2016 6:10 am
Probably mapping to pressure rather than location.
Posted: Thu Feb 04, 2016 2:50 am
by blueleaf
I had to reinstall the firmware several times but it seems to be working properly now.
