1.2
1.2
Postby TheSupport@KMI » Fri Dec 21, 2012 4:48 pm
Y'alls might want to check out the QuNeo downloads page:
http://www.keithmcmillen.com/QuNeo/downloads/
Merry holidays!
KinBlu
Re: 1.2
Postby KinBlu » Fri Dec 21, 2012 5:17 pm
AAAAH!!! YAY!! so excited!
THANK-YOU KMI!!
Merry solstice!
yns
Re: 1.2
Postby yns » Tue Dec 25, 2012 12:04 pm
Is there a changelog anywhere?
jscott
Re: 1.2
Postby jscott » Tue Dec 25, 2012 1:24 pm
yns wrote:Is there a changelog anywhere?
Yes, see: viewtopic.php?f=49&t=818
There is also a pdf file "QuNeoVersion1.2_NewFeatures.pdf" included in the 1.2 download that describes the changes.
lyrael
Re: 1.2
Postby lyrael » Thu Dec 27, 2012 8:57 pm
Is there an official place for bug reports with 1.2? My quneo crashed while updating a present and now every time i reconnect it I can update presets once before it crashes again. Also when updating preset my quneo doesn't appear to be actually getting updated as my changes are not reflected in the quneo's behaviour.
Jee-Bee
Re: 1.2
Postby Jee-Bee » Fri Jan 04, 2013 8:58 am
A little Edit about Editor Version 1.2
In windows and mac the shift key is for selecting everything between start point and end point.
(Like pad 1 is selected and you selected pad 4 that pad 2 and 3 select automaticly). And cmd or ctrl are for individual selections (only pad 1 and 4 previous example).
In mine opinion this is more logical. could this implemented in version 1.2??
bambowlett
Re: 1.2
Postby bambowlett » Fri Feb 01, 2013 8:58 am
I just purchased a QuNeo yesterday (very happy with it!) but I cannot get it to work with the Editor 1.2 at all. It seems to register fine with the older Editor, and I can update the firmware and change the presets the QuNeo using Editor 1.1. Whenever I load Editor 1.2 t it doesn't display "QuNeo 1" in the lower left corner, and it displays "Not connected" when I click the About section in the Help menu. Trying to update or load presets seems to do nothing.
I'm on Windows 7 and mainly using the QuNeo to control Ableton, so it's a real pain not being able to access the newer features. Has anyone else had this issue?
Re: 1.2
Postby TheSupport@KMI » Fri Feb 01, 2013 12:51 pm
You might want to check out the "Hotplugging on Windows" section in the document I've attached to this post — it was just recently made and hasn't been posted anywhere yet. It's a zip because the forum seems to not like pdf files.
quneo-firmware_troubleshooting.pdf.zip
QuNeo firmware troubleshooting guide
(77.07 KiB) Downloaded 296 times
bambowlett
Re: 1.2
Postby bambowlett » Sat Feb 02, 2013 8:14 pm
Thanks so much for your quick response, the hotplugging advice worked perfectly. 1.2 just made my QuNeo even more amazing
deteez
Re: 1.2
Postby deteez » Sun Feb 03, 2013 9:43 am
can anyone help me figure out why with 1.2 now when im using ableton and i switch from preset 9 (clip launch) to presets 1-4 to control the drum rack or instrument and i want to switch back to preset 9 all the buttons in preset 9 still just output values for presets 1-4. also loose red box navigation ability when switching. ive tried everything i can to figure it out, reverting back to 1.1 fixed the problem so i guessing it has something to do in the firmware update? i reallllly want to use the features in 1.2 editor but when i update i get the wierd connectivity issues. could i be doing something wrong? would love to hear back from you guys thanks!
