Static Pad Bank
gmslayton
Static Pad Bank
Postby gmslayton » Sat Dec 13, 2014 12:50 pm
Just bought a Quneo and so far I love it. That being said I would like to know if it would be possible to only bank select certain pads.
Say I want to have the top 8 pads in grid mode, to control loopyHD. Then I want to map the bottom 2 rows to drum pads. It would be awesome to be able to bank select the bottom 2 rows while leaving the top 2 rows static.
I would assume it could be done with a simple check box to opt out of bank select since it seems to be global for all the pads.
Keep up the great work.
Re: Static Pad Bank
Postby emmett@KMI » Tue Dec 16, 2014 12:03 pm
As far as I know, enabling banks for pads will affect all pads.
Re: Static Pad Bank
Postby TheOtherSupport@KMI » Tue Dec 16, 2014 5:10 pm
Deleted. Faulty Advice.
Re: Static Pad Bank
Postby emmett@KMI » Tue Dec 16, 2014 5:34 pm
I could be wrong but I believe that the transpose offset is global rather than per pad.
Re: Static Pad Bank
Postby TheOtherSupport@KMI » Wed Dec 17, 2014 5:49 am
Yeah, you're correct. I should always test things before handing out advice.
gmslayton
Re: Static Pad Bank
Postby gmslayton » Wed Feb 11, 2015 10:44 am
Thanks for the reply. Is this a feature that could be implemented?
