Document the SysEx messages
slinky
Postby slinky » Tue Sep 18, 2012 10:11 am
Please!
E.g. what does this mean:
F0 00 01 5F 7A 1E 00 01 00 02 30 09 7E 1C 00 00 F7
Re: Document the SysEx messages
Postby TheSupport@KMI » Tue Sep 18, 2012 2:10 pm
Which SysEx messages are you referring to exactly?
slinky
Postby slinky » Wed Sep 19, 2012 9:32 am
SupportzKMI wrote:Which SysEx messages are you referring to exactly?
Well, what I'm after is some way to modify the pads, sliders, buttons, etc. without using the Windows/OSX programs. I.e. some way to configure the note, pressure, sensitivity, x, y, x/y return and so on.
I presume the programs just send SysEx messages to modify the preset data stored on the device.
Perhaps this is not the case - how does the preset editor then communicate the new values?
runtoo75
Postby runtoo75 » Tue Dec 23, 2014 1:40 am
is there going to be any sort of Max6 SDK or template to use allowing easy mapping of sensor values, I know you guys are pretty nifty Max users and just wondered if there were plans for this. I find this a valuable tool when using my Softstep with Max and this would be great with the QuNeo too.
You can check out our latest 70-640 - vce exams and 300-207 - actual tests - braindumps.com exams written by our pba to help you pass www.kumc.edu You can also purchase Florida Southern College
jscott
Postby jscott » Thu Dec 25, 2014 8:59 am
slinky wrote:Please!
The message "F0 00 01 5F 7A 1E 00 01 00 02 30 09 7E 1C 00 00 F7" means load preset #10.
The documented sysex messages so far are load presets 1-16, tether mode on, tether mode off, and LED toggle.
All of these start with "F0 00 01 5F 7A 1E 00 01 00 02" so that is something of a header.
Fields seem likely to include actually memory addresses in the firmware that are targeted for writing, so it is possible there is not a consistent mapping between firmware versions as new fields are added, and thus documenting everything would be problematic.
Detailed patch data seems to be writable only in bulk, as a complete patch.
Plus a small number of global parameters such as patch select and tether mode, as mentioned. It seems these global parameters can be presumed to remain constant across firmware releases.
