banks and x/y/pressure control
djzach
Re: banks and x/y/pressure control
Postby djzach » Mon Feb 18, 2013 5:19 pm
I feel silly.
I found an obvious solution.
instead of banks I just have 4 nearly identical presets and use the presets as banks. works like a charm.
duh. :roll:
even though a full-fledged bank system WOULD be superior, this is a more than adequate workaround, as I don't ever think I'll need 16 full presets.
defenestration
Postby defenestration » Tue Mar 19, 2013 10:20 am
I'm all about full-fledged banks for the Pads!! :mrgreen: :mrgreen:
switching presets from the quneo takes 2 buttons presses and a brief pause as the preset changes, switching a bank only takes 1 button press and is essentially instantaneous
speaking of banks, why are all four always active all the time for whatever you've enabled? using the rhombus button I often just want to have it toggle between 2 banks, so I don't have to cycle all the way through to only switch between 2 banks
Postby TheSupport@KMI » Tue Mar 19, 2013 11:59 am
I'll add the number of active banks as a feature request. That seems like it could be interesting.
I only see it being somewhat necessary if you're using the rhombus button for pad banks. With the up/down buttons you can just use up then down.
Jackenite
Postby Jackenite » Mon Nov 04, 2013 10:02 pm
+1 for complete banking system, at least complete transpose of all parameters.
+1 to channel banking that's brilliant
+1 for a 'bank everything' option on arrows. (Also brilliant)
+1 to Definable banks (at least rhombus, I see your point)
You can replicate the first two onto the last two, as a workaround, if you only need two.
If only one set of arrows by the horizontal Faders banked ALL the horizontal faders,
the other three left/right arrow pairs could be used for banking other things.
Basically creating a banking controller out of the the arrows sections.
