mometary effects
Jee-Bee
mometary effects
Postby Jee-Bee » Wed Feb 06, 2013 1:30 am
i wanna try to use momentary FX in my sets. but that doesn't work in the way i want it.
I saw this articlehttp://www.macprovideo.com/hub/ableton-live/using-quneo-for-momentary-effects-in-ableton-live and hoped that i cloud answer my problem... not
I use drummode. The note for FX on and x/y/pressure for edit fx and when release effect goes of.
I use ableton and i don't know where i have to set this parameter, is this quneo or Live and where in live.
Lion
Re: mometary effects
Postby Lion » Wed Feb 06, 2013 9:19 am
Live uses Notes for toggle and CC for momentary.
I've done what it sounds like you're wanting to do by changing the minimum value to 1. This is for on-off switches though. Any rotary or fader controls in Live will still get the entire range, I've yet to figure how to limit that.
Jee-Bee
Postby Jee-Bee » Wed Feb 06, 2013 11:34 am
Thanks for the tip!!
Postby TheSupport@KMI » Wed Feb 06, 2013 1:31 pm
Yeah, I would map the pressure CC to the on/off switch in Live, then set the "min" value in the Mappings window to 1. This way anytime you're applying pressure to the pad the effect will turn off and when you release it will turn off.
Jee-Bee
Postby Jee-Bee » Thu Feb 07, 2013 2:09 am
Thanks!! i try it out
Lion
Postby Lion » Thu Feb 07, 2013 5:08 am
You could also manipulate (or limit in this case) the throw of rotaries and faders using mapulator. That way it's not limited to just switches.
Mind that you need Max4Live
Jee-Bee
Postby Jee-Bee » Mon Feb 11, 2013 4:23 am
I don't have M4L (yet) so that's no option
