Propellerheads' Reason 7
a place to share your QuNeo Scenes and Presets
Micronin
Postby Micronin » Thu Sep 18, 2014 7:01 am
I just got a QuNeo and even if it is not really designed for Reason, I am really enthusiastic about this new controller and start this thread to share presets.
Later we may start a thread with ideas regarding improvements of QuNeo for Reason.
Here is a first one designed for the Parsec :
- Horizontal sliders (2 banks) are for the X - Y of the Sound Engines (Bank 1 for A | Bank 2 for B)
- Vertical sliders are for the Envelop Control : Bank 1 : main Envelope Bank 2 : Envelope 1 | Bank 3 : Envelope 2
- Long slider : main volume.
- Rotary 1 : Mod Wheel
- Rotay 2 : A - B balance
- The pads are sending note and I used the x-y function to modify Sound A Engine X-Y. This mess up a little bit your Parsec's sound and make funny effect, you may remove the x-y function.
This preset send instruction to the Midi channel 4. I you want to use it go on the Advance MIDI on the top of your rack and set channel 4 to Parsec (Input).
Have fun and give me your feedback (and your Reason presets ;) )
Reason-Parsec-2.quneopreset.zip
(2.51 KiB) Downloaded 302 times
Re: Propellerheads' Reason 7
Postby TheOtherSupport@KMI » Thu Sep 18, 2014 9:05 am
Might be helpful to post the preset.
Micronin
Postby Micronin » Thu Sep 18, 2014 9:35 am
Oups, sorry about that. Here we go !
Postby emmett@KMI » Thu Sep 18, 2014 10:32 am
Awesome, thanks for sharing!
Micronin
Postby Micronin » Fri Sep 19, 2014 1:57 am
Another one, a 16 pads Matrix and OctoRex triggers.
With this one, you will need to ctrl clic on the pattern enabler of Matrix and Run of OctoRex and select Edit Remote Override Mapping… and press the corresponding pad on the QuNeo that will trig the device.
To activate the device, press the upper side of the pad and to desactive it, press le lower side of the pad.
Beware, this preset can be addictive.
Reason-Matrix-OctoRex-enable-XYtoggle-Master-Level-1.quneopreset.zip
(2.62 KiB) Downloaded 326 times
Return to “QuNeo Preset Sharing Forum”
