How to control Ableton Live
sp_key
Re: How to control Ableton Live
Postby sp_key » Mon Jul 02, 2018 7:52 am
Ok, it now makes sense in terms of the connected expander and CV but I think I have one final question if you don't mind me asking.
I've now selected the right input and output as per your instructions.
I then select MIDI MAP in Ableton Live and I am able to map certain pads to certain functions in Live 10.
However, the QuNexus manual shows a different mapping which is way better than my own personal one.
It shows which pads are used to navigate scenes, launch clips etc.
Am I supposed to do this mapping myself or is there a way to access it?
If the latter, how do you access it? Is there a Demo Live Set somewhere?
In the downloads section, I indeed found a "QuNexus Ableton Live Sets" zip file which suggests this is Live Set download.
However, it's only the python surface control instead.
Cheers
sp_key
Postby sp_key » Tue Jul 03, 2018 2:08 pm
Ok, I have found the demo song. The installation process was far from smooth.
Now, I have the right project, midi inputs/outputs selected, 'D' as a Preset and I can confirm it does absolutely nothing when pressing the pads.
Guys, has anyone managed to make this work? Can't believe noone here is using the QuNexus with Ableton Live!
Any help would be highly appreciated
