pressure CC not reachin 127 / max modulation
an3
Postby an3 » Wed Nov 20, 2013 2:19 am
ive setup CC pressure to several fx in traktor, and no matter how firmly i push i never reach 127.
Tech support: any tips
regards
Re: pressure CC not reachin 127 / max modulation
Postby TheSupport@KMI » Wed Nov 20, 2013 1:03 pm
You can try increasing the sensitivity or raising the gain a little bit in the editor.
an3
Postby an3 » Fri Nov 22, 2013 3:17 am
it's the CC mode so no gain unfort. sensitivity helps !
Does the Gain actual mirror in the CC mode
Sumeraxe
Postby Sumeraxe » Sat Apr 04, 2015 4:03 am
Thanks for that - I was using an external keyboard with a wonky pitch-bend set-up, working as you outlined now.
