send CV out independent of keyboard
devilwidget
Postby devilwidget » Mon Jan 13, 2014 4:30 pm
I'm trying to figure out how to send cv out from a sequencer plugged into the midi in of the expander (which I can do), but then be able to play the qunexus keys through the expander midi out to a midi synth. Presumably its possible, given that the expander has a midi out not a midi thru port?
Re: send CV out independent of keyboard
Postby TheSupport@KMI » Tue Jan 14, 2014 1:07 pm
By default the keyboard should be sending out of the MIDI Out on the Expander, but it'll also be sending out the CV outputs — you just need to turn off the CV part. Do this:
1. Connect the QuNexus to a computer and open up the QuNexus Editor
2. Select a preset you want to modify in the preset library
3. Switch to the CV tab in the editor
4. Set the "MIDI Device Input" setting on all four lines to "USB 3 + Expander" — this will make it so only external MIDI (from Expander input or from USB/computer input) will go out of the CV, no keyboard
5. Save the preset and send it down to the board by clicking the "Save & Send" button
6. Repeat Steps 2-5 for any other presets you want to use this way
Now input to the Expander should go out the CV outs and the keyboard will only be going out of the Expander (and USB if you're ever connected to a computer).
devilwidget
Postby devilwidget » Wed Jan 15, 2014 3:05 am
Excellent! Works like a charm!
