Editor doesnt work on Windows 8.1 64bit
mishik
Postby mishik » Wed Mar 12, 2014 8:57 pm
When I tried to install Qunexus editor on Windows 8.1 64bit it asked for qt4* dll's and installation stopped.
Any suggestions?
Sorry for my English
Re: Editor doesnt work on Windows 8.1 64bit
Postby TheSupport@KMI » Thu Mar 13, 2014 2:17 pm
Sounds like you moved the editor out of its original folder. Did you do that? If so, that's the problem. Those dlls are hidden in the original folder. If you take the editor out it won't be able to find them. If you put it back (or re-download if you already deleted it) it should work.
mishik
Postby mishik » Sun Mar 16, 2014 6:17 pm
It was my fall. I moved the exe file from original location.
Thanks
Postby TheSupport@KMI » Mon Mar 17, 2014 11:35 am
No problem. We should make it more known that moving the app out of the folder (without also moving the hidden dlls) is a bad idea.
