QuNexus CV cables
Pongoid
QuNexus CV cables
Postby Pongoid » Tue Sep 15, 2015 2:21 am
Hey all, I am planning on driving some analog gear that uses banana cables with the QuNexus, but that means also connecting a ground to my synth/s, and I was wondering if anyone would know which cable is the ground on the 1/8" TRS jack. I'm guessing I can connect the ground on my synth to the ground on the QuNexus, and then just plug into CV inputs to my heart's content, correct? Thanks!!
Re: QuNexus CV cables
Postby TheOtherSupport@KMI » Tue Sep 15, 2015 11:53 am
I got this from talking to some folks today:
"it’s technically possible to connect the ground from a QuNexus CV jack to the ground on his synth, but i have no idea if that will work right or damage something. You should probably need to ask an engineer"
The sleeve is ground on the CV connectors, but you are doing this at your own risk!
Pongoid
Postby Pongoid » Tue Sep 15, 2015 2:55 pm
