Please explain the latency in the software
Dallon426
Postby Dallon426 » Thu Jun 28, 2018 7:24 am
I am curious as to why in the USB audio control panel under the buffer settings, I am getting warnings for example
64 Buffers I do not get the warning on Minimum latency settings
However on Low latency setting and everything above I get the warning
This is also true for every buffer setting, low latency setting works with 128 but then if I select standard (and everything below standard) I get that warning. And when that warning is up the audio inside my daw is distorted.
Dallon426
Re: Please explain the latency in the software
Postby Dallon426 » Thu Jun 28, 2018 7:30 am
I just found an explanation in the manual on page 137 in the manual
