2 or more BopPad at the same time ?
jfi
Postby jfi » Sun Dec 30, 2018 10:07 am
Hello !
I would like to know if I can use 2 (or more) BopPad at the same time ?
I’m using Ableton Live on a macOS Sierra.
I have also the Softstep 2 and would like to know if I can use also at the same time ?
Last Question :
If yes : plugging them all in a USB hub will work ?
Thanks you and and have nice Christmas time.
Re: 2 or more BopPad at the same time ?
Postby TheOtherSupport@KMI » Mon Dec 31, 2018 8:27 am
You can use as many BopPads as you have powered USB ports, but you will only be able to connect 1 to the Editor at a time. I would make sure that the presets on each device are sending different MIDI messages, or sending on different MIDI channels.
You can also use an SS at the same time with no restrictions.
When using multiple USB devices with a hub, you should always being using a powered hub to make sure all devices are receiving enough power to properly function.
