12 Step - Power using a camera connection to IOS
Show off your 12 Step tricks here.
3dog
Postby 3dog » Thu Dec 22, 2016 8:17 am
Found that even though my camera connector can be plugged into external power which charges the IPAD Pro while I use it, it didn't furnish enough power to the 12 Step. The lights flash on and off so it was getting some power. I then plugged a usb rechargeable battery pack into the mini usb slot of the 12 Step and found that I could get the lights to stay on and it worked. I then discovered that I could then unplug the battery and everything still works. I guess it just needs that extra boost to get started. 8-)
Re: 12 Step - Power using a camera connection to IOS
Postby TheOtherSupport@KMI » Thu Dec 22, 2016 8:34 am
Yeah, it's an initialization thing. If the 12 Step isn't receiving adequate power on startup, it won't make a connection. Once connected, it seems to be fine with just the power from the iPad.
Return to “12 Step Tips and Tricks”
