K-Mix and Logic
kenhan
K-Mix and Logic
Postby kenhan » Mon Jun 26, 2017 6:13 pm
Can you post some instructions how to configure K-Mix to work with Logic? I've skimmed the manual for both but can't readily find anything that resembles step by step instruction.
Re: K-Mix and Logic
Postby TheOtherSupport@KMI » Tue Jun 27, 2017 5:15 am
I'll just post what I sent you in a support ticket earlier.
We currently do not have a step by step guide for setting up the K-Mix apart from the section of the manual that covers the virtual HUI port in the Editor. You can use this to emulate Mackie control surfaces and provides you with some mixing/transport functionality. Add a Mackie control surface in Logic X, and then follow the steps listed on page 125 of the manual to set up the K-Mix to send the proper messages.
I am actually in the process of putting a blog post together that will cover setting up the K-Mix as a control surface with Logic from the ground up. It's a bit of work, but allows you for tight and fairly customizable integration. Stay tuned for that near the end of the week!
kenhan
Re: K-Mix and Logic
Postby kenhan » Tue Jun 27, 2017 5:55 am
Thanks! Appreciate the response and looking forward to further instructions.
Return to “K-Mix Tips and Tricks”
