Cheerythank
TheOtherSupport@KMI wrote:
If you want to use the script, just without the session component, comment out the session component in the python files.
boulderburns wrote:
Having played around a bit without the script I'm finding remapping the Q on every new project a ball ache. The issue I want to get around is the clash invoked when I want to use an APC mini for clip launching and mixer control and the Q for other functions. The two bits of kit both want to control the red box and it seems they both want to do this slightly differently and as a result they don't play nicely together. Now I don't yet know my Python (working on it) so I have a couple of questions....
boulderburns wrote:1) When you say to comment out the session component, do you refer to the whole of the session component, line by line, or specific lines thereof?
Code: Select all
self.set_highlighting_session_component(self._selector._session)
boulderburns wrote:2) Is the session component referenced elsewhere in other files that also need to be commented out?
boulderburns wrote:3) Am I correct in thinking that after the edit above, I should delete the previously compiled file to force re-compilation?
