An example using Softstep with only standard Max objects
TomSwirly
Re: An example using Softstep with only standard Max objects
Postby TomSwirly » Wed Mar 07, 2012 12:10 pm
Don't give up yet, we must be able to fix this!
I doubt it's the cable, really, at some point trying it couldn't hurt.
> I'm not using the SS cooking, so there isn't a reset command.
You can "reset" from pure MIDI by sending the two sysex commands that represent
standalone off:
https://github.com/rec/swirly/blob/mast ... ble.js#L12
and tether on:
https://github.com/rec/swirly/blob/mast ... ble.js#L25
Now, you're sure you're NOT using the ss patch, right?
Rodrigo
Postby Rodrigo » Wed Mar 07, 2012 1:45 pm
I'm using a tweaked version of the patch in the original post, using a jk.stepcore and 10 jk.softsteps.
Is it possible to send the messages in the js without running it in js? To tether and untether it?
TomSwirly
Postby TomSwirly » Wed Mar 07, 2012 2:02 pm
Oh, you don't need JS at all. You can just send 'em right to a midiout. I was just pointing to that as it was a place online that has the actual numbers you need, is all.
Rodrigo
Postby Rodrigo » Wed Mar 21, 2012 5:38 pm
Just discovered an annoying quirk with this.
When using my MIDI keyboard with my max patch, and not having the softstep plugged in, the midiin inside the jk.stepcore is using the sustain pedal data as button press data CC64.
Is there a way to not have this happen?
