banks and x/y/pressure control
djzach
Postby djzach » Fri Dec 28, 2012 10:02 pm
hey! first post here, just got a quneo for live performance and so far I'm loving it.
I'm using drumpad banks for my live set...
2 banks for rhythmic momentary fx controls, and 2 banks for sample launching.
I would like to assign filters and other fx to the x/y controls of the pads, but when I switch banks, the same 16 x/y controls remain active...
x/y/pressure data on pads should be able to automatically correspond with pad banks, no?
or at least have their own bank control...
!!assuming I'm not missing something!! If I am, apologies.
Has anyone found a workaround or created a script for this functionality? any help would be much appreciated.
thanks!
z
djzach
Re: banks and x/y/pressure control
Postby djzach » Sun Dec 30, 2012 3:01 pm
in fact, a full-fledged bank system including dedicated led controls for different pages would be INCREDIBLE.
Postby TheSupport@KMI » Mon Jan 07, 2013 3:00 pm
Yeah, currently pad banks are really just more of a pad "transpose" function. Only the notes will change while the X/Y/Pressure CCs remain constant.
I'll definitely put this in as a feature request though.
demcanulty
Postby demcanulty » Thu Jan 10, 2013 12:17 am
I inadvertently check this part of the forum less frequently, so apologies ahead of time if my responses lag a little. We talked about this and went back and forth on a number of things. I think part of the issue is the uncertain UI for editing, and part of it is that we just needed to get 1.2 out and see how people used it, so we're still open to new ideas for how things could work. Is the idea that x/y/pressure would transpose as well? Or would you need to hand select x/y/pressure for every bank? Or is it that one would like x/y/pressure to not be active for certain banks?
Postby TheSupport@KMI » Thu Jan 10, 2013 12:17 pm
I imagine completely customizable settings for each bank.
dijidave
Postby dijidave » Thu Jan 10, 2013 5:50 pm
TheSupport@KMI wrote:I imagine completely customizable settings for each bank.
this would give users the most choice, but wh@ we got was much better than wh@ we had B4
8-)
djzach
Postby djzach » Fri Jan 11, 2013 12:13 am
I would be totally happy with just a full bank system.. that basically emulated 4 separate sets of 16 pads.
so the bank would not just transpose the notes of pads, but rather switched them out for another set...
each pad having it's own respective pressure / xy / note / cc values attached.
that would be a lot more useful than just the notes changing.
djzach
Postby djzach » Thu Jan 17, 2013 7:07 am
I would also be receptive to midi/osc routing/mapping solutions... if anyone has any homebrew ideas...
I use osculator>ableton if that helps
jimmy
Postby jimmy » Fri Feb 01, 2013 8:30 am
also for the bank switching controls
it would be nice to have an option for All
so we can switch banks on rotaries, vertical sliders, long sliders and pads
all at the same time.
hyphonetics
Postby hyphonetics » Sat Feb 09, 2013 10:52 pm
jimmy wrote:also for the bank switching controls
I agree. Something else that might be nice would be to have the bank control just make the MIDI channel increase/decrease. I use my QuNeo alongside my NI Maschine and I've got the Maschine using MIDI channels 1-8 and the QuNeo on 9-16 to prevent the controllers from having conflicting messages
