12 step w Ableton control send faders, feedback amounts
tvr
Postby tvr » Sat Jun 14, 2014 9:39 am
Just got 12 step and haven't found how to make the key buttons into up/down sweeps (fader/send control, etc.)
I'm in Ableton Live 9 and need the 12 step to dedicate some keys to control send amounts, delay feedback amounts. So far the default is just bypass or maxed out.
So far, not finding how to do this in the editor.
Re: 12 step w Ableton control send faders, feedback amounts
Postby TheSupport@KMI » Mon Jun 16, 2014 11:47 am
All you need to do is set one of the CC modlines' Source to "Tilt". Then when you tilt a key forward the value rises and when you tilt a key back (toward you) the value lowers.
You should also know that with 12 Step all of these settings are "global" — they affect all keys. Aside from MIDI notes, you cannot currently set up different controls on a per key basis. So if you set up this tilt functionality then all keys will be capable of sending that message.
The SoftStep is more suited to programming different functionality per key (if that actually is what you're looking for).
