Data Source Trigger for Each Sensor
fishuyo
Postby fishuyo » Tue Oct 07, 2014 10:14 pm
It would be awesome if in addition to the top, bottom triggers in the editor there were left, right triggers as well. I could implement this in my software using the live x, live y sources, but it would be nice to have them in the editor to use the led functionality.
Also, I guess this only makes sense for the original softstep, but since the pressure sensors are in the corners of the buttons it would be awesome to have each pressure sensor as a data source. So perhaps also a TL, TR, BL, BR trigger data source.
I tend to target my stomp to a particular corner, because that is how I get the most reliable response from the device, but currently if left and right triggers were added, I'd still be triggering both the top and right triggers by stepping on the top right sensor, where it would be cleaner to have a single trigger for this.
What do you think?
Re: Data Source Trigger for Each Sensor
Postby TheOtherSupport@KMI » Wed Oct 08, 2014 6:05 am
You can access each sensor independently by putting the Softstep into what we call 'Tethered' Mode. This allows you to access the raw data from the sensors. This can be accomplished by sending a sysex command to the Softstep
You need to send Standalone off to the sofstep first: https://www.dropbox.com/s/8wpi1xieqyiom ... f.syx?dl=0
Then you can send Tethered On:
https://www.dropbox.com/s/b3qcn5b1cg10i ... n.syx?dl=0
This should allow you to monitor all the sensors on the Softstep through SSCOM 1
What are you using to develop your software? You can send CC's to the Softstep to externally control the LED's as well, so you aren't limited to the LED functionality in the editor (this is detailed in the manual).
fishuyo
Postby fishuyo » Wed Oct 08, 2014 8:18 am
Thanks for the reply, definitely good to know. I'll take a look at this..
Generally I am using the advanced editor in hosted mode to send OSC messages to my applications which are a few different OSC enabled custom applications written in various languages (max, c++, scala).
Connecting directly to SSCOM1 in "Tethered" mode, I would lose the existing functionality of the editor in hosted mode correct?
And I don't necessarily want to reimplement a lot of that.. (i.e., OSC transport and stuff)
