QuNeo Max/MSP Dev Kit Available Now
a place to share your QuNeo Scenes and Presets
Postby TheSupport@KMI » Wed Apr 03, 2013 5:29 pm
Check out the post here: viewtopic.php?f=49&t=1014
dothque
Re: QuNeo Max/MSP Dev Kit Available Now
Postby dothque » Fri May 09, 2014 10:58 pm
Hello,
I get wrong functioning with this Dev Kit.
The sliders info is showing in the Pads.
the example with @ pad 2 showing the sliders as the X/Ys values.
I guess that there is a mismatch beאween the notes .
any suggestions?
Postby emmett@KMI » Mon May 12, 2014 2:56 pm
Are you putting your QuNeo into tethered mode?
dothque
Postby dothque » Tue May 13, 2014 6:10 am
I tried to use that option but still no luck.
In the Patch i see that the Sliders should be on Channel 3 and the buttons on 4.
in the Quneo editors all in CH.1
the Vertical Sliders CC are 3 - 6.
this explains why the move the Pad 2 X Y values.
setting Pad 2 X and Y to 4 gives a better result but still need to fine tune it.
I will play around again with the tethered mode.
Any steps needs to be taken prior to that?
Thanks for your reply!
Postby emmett@KMI » Tue May 13, 2014 12:03 pm
It sounds like you're not properly in tethered mode. This dev kit is made to handle the raw data so you should be seeing 16 CCs per slider.
dothque
Postby dothque » Wed May 14, 2014 1:36 am
The guy that uploaded the Patch told me the exact same thing.
So I guess that is the solution.
Thanks for advising.
dothque
Postby dothque » Wed May 21, 2014 4:14 am
Today I have finally got it, in tethered mode the pads locations are inverted.
so pad number two becomes pad number 14.
now I wonder if it is possible to turn on the LEDS as well?
Thanks for the tips :)
Return to “QuNeo Preset Sharing Forum”
