Newbie to Quneo with a few questions.
Ninjazz
Postby Ninjazz » Sun Dec 01, 2013 8:43 am
So as I understand it, there are 16 presets. If you create your own it overwrites the existing one (but you can always reset to default). To save the custom preset it must go to an external folder that you load in. To get certain control options to customize you have to either choose one of the pre-existing Drum presets or pre-existing Grid depending on how you want to set up the controller.
Have I got it all right so far?
Also I can't seem to get the rotary pads to act like...A rotary. I tried mapping to a control knob in Ableton, I assume it's the "direction" or "Location" (???) action to set, it mearly goes on/off. As well in the Ableton preset the video shows that a clip can be launched and stopped with the same pad corner but mine mearly relaunches.
Thanks for the help.
Re: Newbie to Quneo with a few questions.
Postby TheSupport@KMI » Mon Dec 02, 2013 2:52 pm
For the rotary behavior, it's got nothing to do with the QuNeo and everything to do with Ableton. The way an endless encoder (a "rotary") works is that when going one direction it sends a series of values of 127 and when traveling the other direction is sends a series of values of 1. If the thing you're mapping to just responds as though these are "absolute" values then it will appear to just go between on and off.
When mapping an endless encoder you need to tell Ableton to interpret the data properly. There is a menu to do this that is overlooked very, very easily. It's in the bottom-left corner of Live when mapping something. You generally need to make the mapping first, then it should show up. I've also had to click away from the control I was mapping and then click back to it again in order for it to appear — it's rather finicky. Anyway, just set it to "Relative (lin 2's Comp)" and it should be good to go. I attached a screenshot of what the menu looks like.
For the QuNeo/Editor stuff, I'll clear up some potential misconceptions with edited/custom presets:
When you modify and save a custom preset it gets saved in a "presets" folder in the package contents of the editor itself — there aren't any external presets/folders happening. When you "export" a preset, then it's saved externally. Exported presets are generally for backup purposes, transferring presets to another computer, sharing presets with a friend, or just for storage when you have more than 16 presets you want to keep. Once imported to the editor, they exist inside the editor. QuNeo Editor does not modify any presets in an external presets folder.
To view the real presets folder on Mac you right-click the editor and select "Show Package Contents", then navigate to Contents --> Resources --> presets. On Windows the presets folder is on the same level as the executable (visible and out in the open).
Not sure what you mean by "to get certain control options to customize". You can completely clear a preset (go up to the Edit menu and select "Clear Current Preset") and all options will still be there.
The very hidden way to set up an endless encoder in Ableton
Ninjazz
Postby Ninjazz » Mon Dec 02, 2013 4:34 pm
Ah, thanks.
So some of the presets are Drum mode and others are Grid but I can clear any one of them to make a preset exactly how I like. As for saving a preset let's say I mod preset 5 and save. It remains the same post mod but I can always reset it to factory original, so I would then loose my modded preset. So I assume I would need to export the modded preset to a folder in order to save it permanently (this assuming I still want to use the original preset 5 at some point). Imported presets simply replace one of the sixteen factory ones. There is no "preset 17" for example. That's how I am understanding it.
Postby TheSupport@KMI » Mon Dec 02, 2013 5:48 pm
All correct. It would be nice if we could get some sort of preset library management going on in the editor though — similar to what QuNexus has.
Jackenite
Postby Jackenite » Tue Dec 31, 2013 2:25 pm
+1001 to a preset library management system for the Quneo Editor.
