Problem with MIDI to CV using iPad or Mac
davideo
Postby davideo » Mon Dec 01, 2014 12:42 pm
I'm trying to use my QuNexus as a MIDI to CV controller to send a sequence to my Moog Werkstatt. I am able to send Gate and Pitch CV from the Gate/CV1 port on the QuNexus if I press the keys on the QuNexus. If I send MIDI to my QuNexus from an iPad or from my Mac, the keys will light up correctly but no control voltage is sent. I am using the factory defaults found in the QuNexus editor.
What am I doing wrong? Thanks for any help!
Re: Problem with MIDI to CV using iPad or Mac
Postby TheOtherSupport@KMI » Mon Dec 01, 2014 1:44 pm
Have you made sure that you are sending on the right channel? It seems that all of the factory presets are set up to listen to channel 2.
davideo
Postby davideo » Mon Dec 01, 2014 9:16 pm
Thanks for your help! The problem was that I was sending on the wrong port. Everything is working fine now. :D
Postby TheOtherSupport@KMI » Tue Dec 02, 2014 6:40 am
Perfect!
altmuse
Postby altmuse » Sat Aug 13, 2016 2:14 pm
Hey!
I'm about to head out to get a tap to ground my connection from QuNexus to my Moog Werkstatt. Did you make your own cable by splicing a mini to the Moog lead? Or is there something out there pre-made?
Thanks! Amy
wolfereeno
Postby wolfereeno » Mon Sep 19, 2016 11:08 am
Pardon me for the sidetrack.
But is it actually possible to use the Qunexus to send sequenced midi from my workstation to CV? That would be way cool!!
So far I've only just started to experiment with using it as a live CV controller.
Thanks
Postby TheOtherSupport@KMI » Mon Sep 19, 2016 12:45 pm
Yeah, you can send notes/ccs to MIDI port 3 from a sequencer, and have it convert it to CV.
wolfereeno
Postby wolfereeno » Mon Sep 19, 2016 1:04 pm
wow! Thanks. Super cool. Can't wait to try it.
