Wireless 12 step?
Danny G
Wireless 12 step?
Postby Danny G » Thu Jan 15, 2015 12:40 pm
Anybody got a wireless system running on their 12 step or similar midi controller?
I know Roland do this http://www.roland.co.uk/products/produc ... spx?p=1231
And m-audio do this http://www.soundonsound.com/sos/nov06/a ... dair25.htm
But I think it's for midi outputs only. Is there a way of running a wireless usb system? Anyone with any experience?
:ugeek:
Re: Wireless 12 step?
Postby emmett@KMI » Thu Jan 15, 2015 3:04 pm
We make something like these called the Rogue, which will enable you to use the QuNeo, QuNexus, 12 Step, and SoftStep wirelessly.
You will need a male mini-USB to female micro-USB cable in order to connect the Rogue to the Expander port on your controller.
http://www.keithmcmillen.com/rogue/tour
3dog
Postby 3dog » Thu Oct 27, 2016 7:47 am
Danny G wrote:Anybody got a wireless system running on their 12 step or similar midi controller?
:ugeek:
Well, I have sort of a wireless set up going but I do use some wires. If you have a Mac or IOS device then you can use a free IOS app called Apollo. You need to have bluetooth turned on all your devices as it uses Bluetooth LE which I find has not noticeable latency if you are in close range. What I do is plug a rechargeable usb battery into the 12 step's mini usb port and the lights light up. Then plug an IOS device using a camera connector into the usb b port of the 12 step. Set up the Apollo interface, in my case I interface both an iPhone 7 plus and a Ipad pro along with my Macbook and then the 12 step will trigger your midi programs on both IOS and Mac OS at the same time.
3dog
Postby 3dog » Sat Jan 26, 2019 4:05 pm
:ugeek:
I used a USB B cable to USB mini into the PUC+ and all the lights lit up on the 12 step on battery power. This is a wireless Bluetooth Le solution to Mac or Ios and it works. The PUC+ comes with a special cable so you can power it with a usb wall wart or usb batter pac while still connected to the 12 Step.
