emmett@KMI wrote:For me it works every time. You might be thinking of a toggle as something that has to be pressed twice to get to work but actually what is happening is that each time you press that key it will alternate between sending out the number in the "Toggle CC Value" and Toggle CC Return" fields. If you put the same number in both fields then you will send that value every time the key is pressed.
On your controller layer page, if you only want to send out CC data but not notes, on each desired key:
* Set note number to off
* Pressure CC to off
* Tilt CC to off
* Set your CC# in the "Toggle CC" field
* Set value and return to the desired value
* Don't forget to save and send
* Make sure you are testing the correct preset on your QuNexus (you have four slots)
It may help to use a MIDI monitor such as Snoize MIDI Monitor or MIDI-Ox to see what data is being output from QuNexus port1.
Please let me know if it still doesn't work for you.
