QuNexus and Moog style s-triggers
RadicalAns
Postby RadicalAns » Fri Jul 24, 2015 7:13 am
A friend of mine has a Moog MG-1 and I was just thinking about if we'd be able to control it over MIDI using the CV outs of the QuNexus. I know that it supports 1V/Oct fine. However, it doesn't use a traditional gate, but instead uses a s-trigger. Does the QuNexus support this out of the box, or will I need to wire up a gate to s-trigger converter box?
Re: QuNexus and Moog style s-triggers
Postby TheOtherSupport@KMI » Tue Jul 28, 2015 7:11 am
You can set the QuNexus to use S-Trigger in the Editor. No fancy box needed :).
