Simple LED Toggle green/red - none/blink/green
pettervagan
Postby pettervagan » Sat Nov 11, 2017 12:30 pm
Hi! Here´s a couple of easy LED-toggles making it easy to see if your Midi-function of choice is ON or OFF (or whatever you chose to do with it).
It actually was a PITA to figure this out for me being the noob I am, so I thought I´d leave it here in case any one else need the info having just bought it and tumbled down the rabbithole.
Toggle between steady Green and Red.
Initially no LED, then toggle between blinking Red and steady Green. When you press any other pad it goes back to no LED. (For instance: first press start recording a clip in Ableton Live, second press starts playing the loop/clip. You could also add an extra line with a (Source) [Long Trig], different CC and LEDs both to OFF to stop the clip again for instance, then you could contain it all to one pad.)
Anyway, hope it helps someone some day!
P
gilsy
Re: Simple LED Toggle green/red - none/blink/green
Postby gilsy » Wed Dec 13, 2017 11:06 am
Hi
Unfortunately, the images are not available !!
And it seems to be very interested !
G
