effects (FX) AUX send + AUX return in same channel
mendomusic
Postby mendomusic » Thu Mar 08, 2018 4:21 pm
Dear KMI Team,
I would like to perform the following routing:
CHANNEL INPUT [1] --> AUX Send --> outboard FX --> AUX Return --> Master
CHANNEL INPUT [1] --> --> Master
An example would be the return rotary in the AUX section of the following mixer:
https://media.musictri.be/media/PLM/dat ... _Top_L.png
So basically, the question is:
How do I configure a AUX return into the same channel with K-Mix?
Or, does this mixer not provide aux return?
My interpretation of the diagram on top of page 32 of the manual suggest this.
Do you confirm?
Thanks in advance and regards!
Re: effects (FX) AUX send + AUX return in same channel
Postby TheOtherSupport@KMI » Fri Mar 09, 2018 6:56 am
Not entirely sure what you're asking here, but you will need to use another input channel in an aux send/return scenario on the K-Mix.
mendomusic
Postby mendomusic » Sun Apr 15, 2018 4:50 am
OK, I understand.
Playing with Pre / Post S ends fader settings for aux helps a bit to get the desired effect.
Great that this can be toggles from hardware itself.
Regards.
