Assigning different CC parameters on a single pad in Ableton Live
lewiskeller
Postby lewiskeller » Wed Aug 29, 2018 9:47 am
On one quadrant if I set pressure to send on CC 1 and radius to send on CC 2 when I enable MIDI mapping mode in Ableton it only recognizes one of them. I've been changing the preset in the BopPad editor to only send one of the parameters, mapping it in Ableton and then changing the preset to send the other and mapping it in Ableton and then enabling both parameters in the preset and then they'll both track in Ableton. However this feels really clunky.
On my QuNeo I hold down the mode button for a few seconds and different CC values on a single pad are sent to mapping depending on where on the pad I press until I press the mode button again. Is there a similar function for the BopPad? Thanks!!
Re: Assigning different CC parameters on a single pad in Ableton Live
Postby TheOtherSupport@KMI » Wed Aug 29, 2018 12:27 pm
If you're on Mac you can use the 'Solo' button to make the BopPad only send one data source at a time.
If on Windows, due to their MIDI implementation, its a bit more tedious.
lewiskeller
Postby lewiskeller » Sat Sep 01, 2018 3:57 pm
Fortunately I am on a Mac. I'd wondered what that solo button was for! Thanks so much!!
