Flashing lights when using Ipad
3dog
Postby 3dog » Sat Jan 26, 2019 8:29 am
I just started using the 12 step again and noticed the lights stop flashing after 6 flashes and they come on with two different iPhones with wired power using the usb adapter but they just keep flashing when I use the same set up with two different iPads. Problem solved after I switched from the iPhone wall wart to the iPad wall wart. It just was not getting enough power.
Re: Flashing lights when using Ipad
Postby TheOtherSupport@KMI » Tue Jan 29, 2019 8:52 am
Yeah, the flashing LEDs indicate the device is nor receiving enough power. Use the power supply that provides that successfully powers the device and you should be fine.
