Downloading Preset from SoftStep
Posted: Sun Nov 06, 2016 2:19 pm
by depuratumba
Hi
I have a SoftStep v1 wich I've been using to control iPad apps.
I created a custom preset some time ago, on a PC. I've recently moved to Mac since my PC died, so I downloaded SoftStep Editor again.
the thing is, when I connect the SoftStep it doesn't show me the current hardware configuration, but the standard templates.
I wish to download the current layout (wich is just one scene) to modify it, and also add a new scene... si this possible? I couldn't find the way, hope you can help me
thank you!
Re: Downloading Preset from SoftStep
Posted: Mon Nov 07, 2016 5:15 am
You can't get presets from your SS to a computer.
yOu'll have to remake the preset, or start from scratch.
Posted: Mon Nov 07, 2016 6:34 am
by depuratumba
ouch, that sucks... thanks for replying
Posted: Mon Nov 07, 2016 11:50 am
by depuratumba
I have one more question - I'm redoing the presets, this time I'll have two scenes loaded. my question is: do I have to run the "Export Preset" twice? one for each scene? or it exports the whole setlist? thank you
Posted: Mon Nov 07, 2016 4:15 pm
Little confused by all the presets/scenes talk. There isn't a concept of 'scenes' in the newer SS Editor.
You shouldn't have to Export anything either. Unless you're moving the presets from one computer to another.
Just create the presets, put them in your setlist, and send to the Softstep.
Posted: Mon Nov 07, 2016 6:00 pm
by depuratumba
what I meant is I have two "layouts" on the playlist (to control different apps, I scroll through them with the Nav Pad)
I want to export them precisely for that reason - so I don't loose everything if I have to change computers / format in the future.
Posted: Tue Nov 08, 2016 4:54 am
You have two presets, forget the other words because they add confusion, just use presets.
You can export them individually, and then reimport them later.
Or you can copy your entire presets folder (Right click SS Editor -> Show Package Contents -> Contents -> Resources) to backup your setlist and presets. (be sure to copy the folder and not the .zip)
