No raw data from expression pedal in Hosted mode
aspiers
Postby aspiers » Wed Jul 19, 2017 11:42 am
Hi there,
When my SoftStep is in Hosted mode and I'm in the advanced editor, I can get immediate feedback on whether modlines are working correctly by looking at the Raw and Value fields whilst pressing a key. However if I attach the expression pedal and set up a modline with "Pedal" as the Source, the Raw and Value fields remain permanently at 0, even though this modline works correctly. That makes it much harder to configure the data modifiers correctly, and also means that the only way to verify that the modline for the expression pedal is correct is to hook it up to a MIDI device and see if it works. Is this a bug, and if so please can it be fixed?
Thanks a lot!
Re: No raw data from expression pedal in Hosted mode
Postby TheOtherSupport@KMI » Thu Jul 20, 2017 8:24 am
What is your OS?
So you're saying you're not getting data in the raw box in the modline in Hosted Mode, but data is coming out of the modline to it's destination?
Users browsing this forum: No registered users and 5 guests
