Problem With Traktor LED Feedback
Posted: Fri Jun 14, 2013 7:05 am
by JoeOsoDopke
I'm trying to assign the 2 lower horizontal faders in the traktor preset to be low/mid/high eq knobs, and that's working fine; I just am using the two arrow buttons next to each fader to toggle between the frequency knobs. Unfortunately, for some reason I can't seem to get any LED feedback whatsoever. I am doing the exact same settings as the filter output and still nothing. Anyone know what I'm doing wrong?
Re: Problem With Traktor LED Feedback
Posted: Fri Jul 19, 2013 5:54 am
by arrjaytea
Joe, would you mind posting up your template?
I'd be happy to have a look for you.
Posted: Thu Aug 01, 2013 3:38 am
by machine_
sorry to ask a stupid question, but have you looked at the quneo manual to see which channel and CC's the quneo needs to receive?
Posted: Thu Aug 01, 2013 12:41 pm
by TheSupport@KMI
Yeah, the QuNeo has a set of fixed MIDI messages that will light up the LEDs. The two lower horizontal faders respond to CCs 8 and 9 on channel 1.
In addition to setting up the input (QuNeo controlling Traktor's EQ) you also need to set up the output (Traktor's EQ sending a CC message to control QuNeo LEDs).
I've attached a screenshot of what it would look like. The only difference would be the "Out-Port" up top should be set to QUNEO (I just didn't have one plugged in when making this). This example will output a value from 0-127 on CC 8 (bottom horizontal fader) whenever the low freq adjust on the EQ is moved.
Posted: Wed Oct 09, 2013 2:48 am
by phoolish
The midi input mapping for LED feedback is not correct for notes in Traktor. CC's work fine, but notes are off by an octave. I assume this has to do with the fact that quneo mapping works from -2 to 8, while traktor uses -1 to 9.
Examples (Quneo = Traktor)
1st horizontal left arrow
C1 = C2
Pad 1 Red
C#-2 = C#-1
Also, if your mapping includes any -2 notes it automatically bumps the entire map up one octave as well.
Posted: Wed Oct 09, 2013 12:55 pm
by TheSupport@KMI
Yeah, this is because there are two different MIDI standards: C4=60 and C3=60 (there is also some rarer stuff that goes the C5=60 way).
We follow the C3=60 way.
