I was just wondering if anyone has used the QuNeo with AudioMulch, and if so, how they set up the parameters. I just got the QuNeo, and so far I've only been able to get a few of the pads or sliders to be recognized, and they primarily only work as toggles (even though in the QuNeo Controller, I have them set to Normal function).
The biggest problem that I can see is that I can't find anyplace in the Mulch MIDI Parameters to set anything but the Port, Channel and CC#.
Please correct me if I'm wrong, but with the QuNeo, you need to be able to assign the Direction, Location and Note info too, right? I don't use MIDI for much, so I'm no expert, and like I said, I just got the QuNeo, but after reading all the documentation, I'm still stuck.
Thanks for any help!
UPDATE: I just discovered the CoMA Mode. Haven't had the opportunity to try it, but it sounds like that should take care of the issue. Don't know how I overlooked that...
