I think there might be a problem with the NavPad's 'Nav Y Inc-Dec' data source.
When I press the North or South key of the Nav Pad of my SS1, nothing happens in the advanced editor? I mean, no value shows up in the red boxes (raw, value, result)? This is not the case with virtually every other source of the keys & NavPad. I tried it's counterpart on one of the keys (Y increment), and it works fine: as I press the top or bottom of the key, the value will increase or decrease accordingly.
Additionally, when I use any of the other data sources that do work with the NavPad, it will input data and show the value according to how I press the NavPad in the first two red boxes 'Raw' and 'Result'...but when it then goes through the 'Table' (set to Linear), no data is output in the last red box, the 'Value'! Which in effect means it's not sending any MIDI signal out, and I therefore can't control anything with it??
Am I missing something?
Could someone please try this with the NavPad on their SS and report back, just to see if it's only me or a general problem...or a normal behaviour?! (KMI support?)
Thx!
Chumbo
